Old 12-20-2017, 10:11 AM   #1
brillo
Drives: 2013 Firestorm FR-S
Slight Suspension Wiggle/Shimmer in Corners
When taking a corner or curve hard I notice a slight wiggle or shimmer? in the suspension mid corner. I'm not sure if I'm feeling my tires roll over on the sidewalls (they are Pilot SS at 35psi), my suspension bushings or something else. This is street driving so I'm not pushing the car much beyond 6-7 10ths.
My bushings are stock save the front LCA bushing which is an upgraded whiteline bushing for some additional caster. Would that be causing the issue since its different than the rear LCA bushing?
Would upgraded sway bars help with this situation? I've been considering an upgrade.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 12-20-2017, 10:19 AM   #2
churchx
churchx's Avatar
Drives: 2014 GT86
Hmm. Imho rear subframe bushings might help more then sway bars for this case/wished result of less slack/movement. I might be totally wrong, so wait for someone more competent in suspension to answer
Old 12-20-2017, 10:26 AM   #3
Icecreamtruk
Drives: Track preped NA FRS
Probably tire rolling over, MPSS have the squishiest of sidewalls.
Old 12-20-2017, 10:44 AM   #4
Try bringing the tires up a few PSI and see if that changes anything.
Slight drifting bad for suspension? orangespark Suspension | Chassis | Brakes -- Sponsored by 949 Racing 17 12-23-2015 10:55 AM
Corners, corners, corners :-) Artalos BRZ Photos, Videos, Wallpapers, Gallery Forum 4 06-23-2015 12:27 AM
Decreasing radius corners ZionsWrath Other Vehicles & General Automotive Discussions 48 11-11-2013 07:34 PM
FS: OEM Clear Corners for FR-S OCFR-S Exterior Parts (Aero, Lighting, Etc.) 2 11-07-2012 12:07 PM
Smoked jdm corners Jason952 Cosmetic Modification (Interior/Exterior/Lighting) 4 10-22-2012 12:23 PM
