Old 12-14-2017, 04:05 PM   #1
hpde_addict
Drives: '18 Camaro V6 1LE
Why does car understeer when going downhill?
Intuitively, I thought that when the car is going downhill, more weight is transferred to the front tires, leading to the front tires gaining grip and rear tires losing grip. However at the Thunderhill skid pad, I noticed that when going downhill, it is much more difficult to get the car to oversteer compared to level and uphill. And when I'm already drifting in the downhill portion, my car tends to go outward like in understeer. The test was just driving around in a constant-ish circle, progressively adding throttle. What's mechanics are happening that's leading to this behavior?
hpde_addict is offline   Reply With Quote
Old 12-14-2017, 04:32 PM   #2
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Is your speed the same in the uphill and downhill portions?
If you're going faster downhill it could be that you're going in too hot, which can be why it's pushing.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 12-14-2017, 04:55 PM   #3
Lex_K
Drives: 987S, e46, mkv, frs
Technically you are off camber when you are turning on a downhill.
Lex_K is offline   Reply With Quote
Old 12-14-2017, 05:25 PM   #4
hpde_addict
I don't think I'm scrubbing any speed on the downhill portions, if that's what you mean by "too hot". I drive around in a circle below the limit and then add throttle to start the drift.
Old 12-14-2017, 05:35 PM   #5
Hades
Hades's Avatar
Drives: 2013 Scion FRS
Wouldn't it be harder to get the frontend to move due to weight transfer? i.e. the front weighs more, so it would take longer to react to direction changes
Hades is offline   Reply With Quote
Old 12-14-2017, 05:41 PM   #6
TommyW
TommyW's Avatar
Drives: '13 Whiteout
Is your trac control on or off?
Old 12-14-2017, 05:51 PM   #7
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
I do not claim to know the exact reason or be an expert but I watched this video today and thought of this thread.
Could it be your applying more steering rotation when going down hill like in the beginning of this video? Since that guy was gradually gaining speed then turning the steering wheel more aggressively which pushed the car vs allowing the back end to slide. Up hill you may be just turning less allowing the car to slide more easily?
Just a thought.
Video: https://jalopnik.com/a-donut-is-actu...ift-1821270890
DandoX is offline   Reply With Quote
Old 12-15-2017, 03:00 PM   #8
Weight transfer rate is different.
Old 12-15-2017, 04:00 PM   #9
Ultramaroon
not playing cards
Ultramaroon's Avatar
+1
Old 12-18-2017, 06:55 PM   #10
CSG David
CSG David's Avatar
Weight transfer.
Old 12-18-2017, 07:38 PM   #11
TommyW
TommyW's Avatar
You're probably asking too much of your front tires
Old 01-04-2018, 05:06 PM   #12
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Physics
Going down hill means gravity is adding to your car's momentum and increased momentum means a greater force upon the thing trying to resist or change that momentum (turning or slowing).
Therefore your car is understeering because the tires are overburdened. Either the moment of directional change needs to be reduced (turn in slower or with less radius) or your momentum needs to be reduced by further lowering your speed prior to turn in.
How a car handles directional changes in regards to track slope or pitch is what makes driving (or racing) on tracks with elevation change so enjoyable.
PRO86 | STL | LuckyDog
Old 01-13-2018, 01:39 PM   #13
ROADRACER
Drives: unlimited cheap build N/A track car
I have noticed the same phenomenon on track. You have made a correct observation. I get push on down hill turns and oversteer on uphill turns. This makes getting the car setup for perfect balance in all the turns basically impossible. There may be some way to lessen the effect but I have not discovered it.
ROADRACER is offline   Reply With Quote
Old 01-13-2018, 02:06 PM   #14
TommyW
TommyW's Avatar
You're overloading the front outside tire downhill and overloading the outside rear tire on uphill. Those are the tires responsible for the most grip in those circumstances
Understeer after new wheels carsebuco Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 12-04-2017 05:49 PM
understeer on 17 brz alex.s Suspension | Chassis | Brakes -- Sponsored by 949 Racing 37 09-11-2017 04:05 AM
Not understeer, not oversteer... something else? Mazikowski Tracking / Autocross / HPDE / Drifting 15 07-25-2016 09:24 PM
Do pigs understeer? Thrustin Off-Topic Lounge [WARNING: NO POLITICS] 11 05-31-2014 09:42 AM
03/23 Reviews --> No understeer complaints... bloomy116 BRZ First-Gen (2012+) — General Topics 19 03-26-2012 11:06 AM
