Drives: '18 Camaro V6 1LE
Why does car understeer when going downhill?
Intuitively, I thought that when the car is going downhill, more weight is transferred to the front tires, leading to the front tires gaining grip and rear tires losing grip. However at the Thunderhill skid pad, I noticed that when going downhill, it is much more difficult to get the car to oversteer compared to level and uphill. And when I'm already drifting in the downhill portion, my car tends to go outward like in understeer. The test was just driving around in a constant-ish circle, progressively adding throttle. What's mechanics are happening that's leading to this behavior?
#2 |
Drives: 2013 Firestorm FR-S
Is your speed the same in the uphill and downhill portions?
If you're going faster downhill it could be that you're going in too hot, which can be why it's pushing.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
| The Following User Says Thank You to Shark_Bait88 For This Useful Post: | strat61caster (12-15-2017) |
#3 | |
Drives: 987S, e46, mkv, frs
| The Following 3 Users Say Thank You to Lex_K For This Useful Post: |
#4 |
I don't think I'm scrubbing any speed on the downhill portions, if that's what you mean by "too hot". I drive around in a circle below the limit and then add throttle to start the drift.
#5 |
Drives: 2013 Scion FRS
Wouldn't it be harder to get the frontend to move due to weight transfer? i.e. the front weighs more, so it would take longer to react to direction changes
#6 |
Drives: '13 Whiteout
Is your trac control on or off?
#7 |
Senior gif poster
Drives: 2013 Asphalt FRS
I do not claim to know the exact reason or be an expert but I watched this video today and thought of this thread.
Could it be your applying more steering rotation when going down hill like in the beginning of this video? Since that guy was gradually gaining speed then turning the steering wheel more aggressively which pushed the car vs allowing the back end to slide. Up hill you may be just turning less allowing the car to slide more easily? Just a thought. Video: https://jalopnik.com/a-donut-is-actu...ift-1821270890 |
#8 | |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#9 |
+1
#10 |
Weight transfer.
#11 |
You're probably asking too much of your front tires
#12 |
Drives: Nevermorange FRS
Physics
Going down hill means gravity is adding to your car's momentum and increased momentum means a greater force upon the thing trying to resist or change that momentum (turning or slowing). Therefore your car is understeering because the tires are overburdened. Either the moment of directional change needs to be reduced (turn in slower or with less radius) or your momentum needs to be reduced by further lowering your speed prior to turn in. How a car handles directional changes in regards to track slope or pitch is what makes driving (or racing) on tracks with elevation change so enjoyable.
PRO86 | WTCC | STL
| The Following 4 Users Say Thank You to rice_classic For This Useful Post: |
#13 |
Drives: unlimited cheap build N/A track car
I have noticed the same phenomenon on track. You have made a correct observation. I get push on down hill turns and oversteer on uphill turns. This makes getting the car setup for perfect balance in all the turns basically impossible. There may be some way to lessen the effect but I have not discovered it.
#14 | |
| Understeer after new wheels | carsebuco | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 12-04-2017 06:49 PM |
| understeer on 17 brz | alex.s | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 37 | 09-11-2017 05:05 AM |
| Not understeer, not oversteer... something else? | Mazikowski | Tracking / Autocross / HPDE / Drifting | 15 | 07-25-2016 10:24 PM |
| Do pigs understeer? | Thrustin | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 05-31-2014 10:42 AM |
| 03/23 Reviews --> No understeer complaints... | bloomy116 | BRZ First-Gen (2012+) — General Topics | 19 | 03-26-2012 12:06 PM |
