Old 12-11-2017, 11:27 AM   #1
leevanf
leevanf's Avatar
Drives: 2014 BRZ Limited A/T
Romraider wont open the files from OFT
Hi, I was able to already load my car's orig ECU file on romraider, but when I try to open the XMLs from OFT's download section, I get this error.
I also noticed that the XMLs file of OFT are divided into OFT_ and RR_ files. My particular calid is not present in the OFT_ but is in the RR_ is this ok?
leevanf is offline   Reply With Quote
Old 12-11-2017, 03:05 PM   #2
elBarto
elBarto's Avatar
Drives: Toyota GT86
Try opening the tuned rom and see if you get the same error.
The included definitions aren't meant to be used with original roms.
"Oversteer is when your ass hits the wall, Understeer is when your face hits the wall!" - Unknown Stockcar driver
BeNeLux FB group: GT86/BRZ Owners
elBarto is offline   Reply With Quote
Old 12-11-2017, 09:04 PM   #3
leevanf
leevanf's Avatar
Getting the same error trying to open anything
Old 12-12-2017, 01:36 AM   #4
steve99
Try using an A01G rom and def i know they work, if it still failing then it will be romraixer install issue or maybe java version
Old 12-12-2017, 01:41 AM   #5
leevanf
leevanf's Avatar
I downloaded the java 8 151 and 152 updates at 32 bit already. Any other java i need?
Old 12-12-2017, 02:58 AM   #6
elBarto
elBarto's Avatar
Drives: Toyota GT86
Recently I had a problem with RomRaider. Installed a new Java-version. Reinstalled RomRader, etc.
Try going to C:\Users\<YOUR-USERNAME>\.RomRaider and delete (or rename) "settings.xml"
Then restart RomRaider. It fixed my problems.
I'm using Java9 64-bit and I used to use v8 32bit and 64bit mixed without problems. So no problem (altough updating couldn't hurt)
Old 12-12-2017, 09:42 AM   #7
leevanf
leevanf's Avatar
Followed what you suggested, for some reason, i cannot even load the orig rom again anymore. nothing loads from anywhere, rom/bin/ori/xml definitions, my own stock rom.. etc..
All show that same Error Loading Caught Exception: Invalid Byte 1 of 1 UTF-8 sequence.
Also tried with another computer and same thing happens....
Is this a rom raider problem? its driving me nuts!
I've also already tried installing old, new/ just old, just new versions of java to get the same result. took me 5 hours of trial last night and nothing
Old 12-12-2017, 10:52 AM   #8
elBarto
elBarto's Avatar
Drives: Toyota GT86
As far as I see using google the errors has something to do with the xml.
Tried the rom and def on my system and it works without error.
Are you just opening the xml file or did you load it in the definition manager?
Old 12-12-2017, 12:50 PM   #9
leevanf
leevanf's Avatar
Hah! I finally got it to work!
Question however, say after I do data logging, and would like to make the changes. There would be no point in loading stock and stg1 anymore right?
So I assume I would open the current Stg1 logged tune on the car, and another source tune? or is it possible to simply edit the values on the stg1 tune?
Im just a bit confused because i am reading through wayno's guide to dialing in your tune and at some examples, the copy has to come from another tune, where in some, it seems like you can just copy straight from an excel file or even just edit the numbers alone.
If in theory I do edit the numbers, all I have to do is "save as new image" and that new rom should be ready to load onto the OFT to car?
Old 12-12-2017, 02:14 PM   #10
bababooey
Drives: BRZ SWP Limited -6MT
arent you getting headers soon, & then upgrade to stage 2 tune? id wait to dial in your tune after that.
BUT in the meantime if you want to look through & adjust parameters (like the idle speeds, fan actuation temperatures, or flat foot shifting for example) work from the stage 1 tune that you put onto the car (no need to bother with the stock tune any longer), just be sure to save the new modified file as a different name, to retain the original stage 1 file if you need to start over, or reference the original values. if you want to be extra sure, you can download the tune you applied to the ecu from the tablet to your desktop/laptop. then modify that one. I only say that because modifying tunes can be dicey if you are grabbing random tunes off the internets.
I recently adjusted mine to rescale the maf a little & did the quiet cold start adjustment. after I made those adjustments, file> save as> "modified stg 2 93.bin" but you can rename it to whatever you want. i am by no means a pro, but i recently went thru a ton of reading on several different threads.
Using RomRaider to edit tunes ( ROM) files OFT and non- OFT steve99 Software Tuning 56 11-18-2020 08:41 PM
Romraider defenition files 7Seraph Software Tuning 3 03-09-2016 03:35 PM
OFT files with Tactrix Open Port 2.0 Jaden Software Tuning 20 02-14-2016 08:59 PM
Trunk wont open Kellhound Issues | Warranty | Recalls / TSB 10 11-15-2015 09:45 PM
Simple way to open .iso files notout86 Off-Topic Lounge [WARNING: NO POLITICS] 19 05-11-2013 07:12 PM
