Old 12-09-2017, 01:04 AM   #1
Eazy-V
EcuTek Launch Control Parameters
Just wondering what LC parameters people have set.
I have the LC Rev Limiter H value set at 10rpm, but it’s not as fast as I’ve seen for others. It actual seems to bounce like it’s set to 200rpm.
FBM Base Turbo Kit with GTX2867R and FlexFuel Kit with Walbro 485 / 550cc Injectors
EcuTek Tuned witih Greddy Profec @ 12PSI Shell 91-E73 and 18PSI E73
1993 Mazda MX6 N/A Fully Built on MegaSquirt (work in progress)
2023 Chevrolet Corvette Z51 Stock
Eazy-V is offline   Reply With Quote
Old 12-09-2017, 07:52 AM   #2
steve99
Try reducing the amount of ignition retard from -20 to say -10
Old 12-09-2017, 06:09 PM   #3
Eazy-V
Ok thanks, will give that a shot.
What about afr, leaving it at 9.5 shouldn’t affect bounce speed right?
Old 12-09-2017, 06:11 PM   #4
Tor
Tor's Avatar
Drives: Toyota GT86
If I may ask here too, out of curiosity... How does the Ecutek LC work? Via fuel cut or ignition cut?
Tor is offline   Reply With Quote
Old 12-09-2017, 06:43 PM   #5
steve99
Appears to be ignition based as you can adjust retard amount and also set afr during launch mode
Old 12-09-2017, 06:51 PM   #6
steve99
Easy v if you adjist the launch afr from 9.5 be very carefull to check your open loop afr under wide open throttle. I adjusted that parameter a couple of years ago and it appears their was bug in racerom caused my car to run very lean like 15 afr during wot. Luckly i was NA and on e85 so fair margin for error.
Notice your turbo, ecutek may have fixed it i think it was racerom 8 .
That parameter sgould have only effected launch afr but i confirmed it messed up y full throttle afr
Old 12-10-2017, 04:27 AM   #7
Kodename47
Kodename47's Avatar
Drives: UK GT86
I thought I confirmed this as the DI injection max limits based on the log you sent me? Not raised so capping the DI output causing lean on E85. I've not had this issue on mine, AFR is set up to 11.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-10-2017, 04:27 PM   #8
steve99
Im still running same fueling on e85 no lean condition, when i changed that one parameter it wrnt bad, since moved to newer racerom. It was A02G racerom 7 or 8 cannot remember now. If he is on newer racerom likely ok
My di pulse doesnt get much above 5ms, normally, maybe that parameter has some weird effect on di ratio. Didnt you have some other weird issues with A02G as well and went back to A01G
Old 12-11-2017, 02:44 AM   #9
Eazy-V
I adjusted the timing from -20 to -10, but not too much difference. Could my ACT Prolite flywheel cause the rev bounce to be wider than Hysterious value of 20rpm would indicate.
Btw, I got my RaceRom updated to 9.1 earlier.
Old 12-11-2017, 03:40 AM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
I had a rich issue on RR8 IIRC on the A02G. That may have been caused by using the rear O2 sensor input but I can't confirm. Back on A01G and RR9.1 now.
I wonder whether you want to set the launch and FFS target AFR to lower than you'd expect to see in normal driving anyway.
.: Stealth 86 :.
Kodename 47 DJ:
Old 12-11-2017, 04:10 AM   #11
steve99
From memory i set the launch afr to 12, about same as my eot afr
Old 12-11-2017, 04:13 AM   #12
steve99
I believe that profile determines how quickly the "Power" feeds back in as you launch ie the transition to normal from lsunch mode.
Ive noticed you get buch lessbounce if launch rpm is higher like 5000.
EcuTek Launch Control not working Eazy-V Software Tuning 12 06-11-2017 09:31 PM
OpenFlash Tablet: RomRaider parameters for Launch Control and Flat-foot Shift Shiv@Openflash Software Tuning 118 06-04-2017 04:26 AM
Ecutek launch control puma Software Tuning 6 06-29-2015 04:55 PM
EcuTek RaceROM Launch Control just86 Software Tuning 47 03-14-2014 02:55 PM
ECUTEK Launch Control for AT transmission Kinaa Software Tuning 10 12-22-2013 01:45 AM
