Old 12-03-2017, 07:43 AM   #1
Diz86x
Drives: GT86 Nur spec
Fuel quality and tunes
Hello there,
Im facing a Cel that shows p1235 p0087 and i couldnt figure what it is for 3 months now.
*Sometimes it happens while im just parked and the car is on.
*sometimes it happens when i high rev!
In both conditions the power cuts off immediately and i have to erase the code leave the car off for a few minutes then switch on and drive!
I have the current mods on my car
Jdl uel catted
Trd catback
Perrin CAI
Perrin light weight Crank pulley
And an oft stage2 uel tune!
Our fuel in our country is not that good and our MOGAS 95 would be probably between 92-94 octane!
My question is, is it okay if i tune my car to stage2 uel 91 and refuel what they call 95? Will it fix the issue?
I tried contacting @shiv but no response yet !!
Diz86x is offline   Reply With Quote
Old 12-03-2017, 10:20 AM   #2
steve99
I don't think low octane fuel or tune will cause those codes, both relate to the High pressure fuel pump. It possible you have clogged fuel filter or problem with the low pressure fuel pump in tank as well its not monitored ).
their was a service bulletin out in out country for the high pressure fuel pump code. but you also have second code
P0087 – Fuel rail/system pressure too low
P1235 - High Pressure Fuel Pump Circuit
It looks like you might have a problem with the high pressure fuel pump. these are expensive to replace so maybe take it to a shop to confirm
http://www.google.com.au/url?sa=t&rc...dpY2TH_geybol8
Old 12-04-2017, 07:27 AM   #3
Diz86x
Will try that
Thanks alot for your response mate !
Old 01-26-2018, 06:18 AM   #4
Diz86x
Back again,
So i sent the car to the dealership !
They changed !
1- fuel rails
2- fuel lines
3- fuel pump
4- high pressure fuel pump
But the issue is still going on, so they ordered me a new EDU and the wait starts !
Will update once they fix it !
Old 01-28-2018, 07:56 PM   #5
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Originally Posted by Diz86x View Post
Back again,
They changed !
1- fuel rails
2- fuel lines
3- fuel pump
Make sure the OFT is unmarried before the new ECU is installed!
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Engine, Exhaust, Bolt-Ons 9 01-15-2017 09:40 PM
Zeitronix Ethanol Content Analyzer and Display Kit Red + Flex Fuel Sensor with Fuel L BRZ_HaVoKx Audio/Visual, Electronics, Infotainment, NAV 4 07-16-2016 06:43 PM
Fuel Quality and IAM RustySocket Software Tuning 5 11-12-2015 11:26 PM
Deliciou Tuning Speed Density Tunes - Important Notes and Closed Loop Fuel Correction DeliciousTuning Forced Induction 8 06-15-2015 05:50 PM
15% Off Flex Fuel Kits & Tunes, Through 4/11/15 DeliciousTuning Announcements, Contests, Giveaways 0 04-09-2015 06:44 PM
