Northern California NorCal
Old 12-01-2017, 02:18 PM   #1
svolo4
Drives: FRS
Where to fix engine heads?
Hey guys, could you recommend a shop that can fix a damaged FA20 head in the Bay Area?
Long story short: I got a sweet deal on a bunch of used parts and seller included FBM ported heads for free of charge. (I know it sound crazy, but it is what it is, I spent whole day smiling when I realized how lucky I am)
UPS damaged a package with modified head. It has some dents on a surface facing head gasket because package was dropped. Dents aren't big, maybe 1/8th inch in diameter and not more than 0.5mm deep.
Here is a pic that shows worst dent:
There should be at least two ways to fix it:
1) polish head, cut 0.5mm from it, put a fat metal gasket to keep compression intact
2) Use a welder to put some welding in dents, then polish head in a place where welding is
I don't really need a built motor, but since I got parts, I'm thinking to maybe use them and get a bit more power.
I'm familiar with engine assembly, so I can do most of the work assembling engine myself, just need heads fixed if it's possible.
Any suggestions?
svolo4 is offline   Reply With Quote
Used BRZ Heads pgranberg11 Engine, Exhaust, Bolt-Ons 3 12-31-2017 03:01 PM
2013 FRS Heads and Misc. Engine Parts supersuk Engine, Exhaust, Bolt-Ons 10 09-16-2014 10:03 PM
Heads Up BRZ Available In So Cal ZmZMWagon Southern California 17 06-18-2012 03:10 PM
