Old 11-28-2017, 08:38 PM   #1
Lunatic
Lunatic's Avatar
Drives: 2015 Raven FRS
Head Bolts
If pulling the heads off my FA-20 engine are the head bolts re-usable?
Lunatic is offline   Reply With Quote
Old 11-28-2017, 09:14 PM   #2
humfrz
I would think so ...... but, I fer sure.
humfrz
Old 11-29-2017, 12:48 AM   #3
gtengr
Drives: 2017 BRZ
Look up the fastening procedure for installation. If it's TTY (torque to yield), they must be replaced. I'd replace them regardless or go with studs.
gtengr is offline   Reply With Quote
The Following User Says Thank You to gtengr For This Useful Post:
humfrz (11-29-2017)
Old 11-29-2017, 01:22 AM   #4
humfrz
Well, Lunatic, old humfrz is going to back off my previous post.
What I said was 1940-50 mechanics.
However, after doing a little reading:
http://www.acl.co.nz/wp-content/uplo...-Headbolts.pdf
http://www.enginebuildermag.com/2001...rque-to-angle/
I would error on the side of caution and figure the OEM head bolts were TTI fastened and use new bolts for your rebuild.
Bubba says to ..... screw it and use the same old bolts ......
In reality, if my FR-S's engine needed that much work ..... I'd trade the car in for a new one .......
humfrz
Old 11-29-2017, 08:57 AM   #5
Lunatic
Lunatic's Avatar
I have had one local engine builder tell me they are torque to yield. So new bolts it is. And if going new bolts He said stock bolts are not the best and advised just going with ARP bolts. So if needed, ARP it will be.
Old 11-29-2017, 12:21 PM   #6
wparsons
wparsons's Avatar
If you're pulling the heads anyway, ARP bolts/studs are cheap insurance.
flickr
Old 11-29-2017, 12:29 PM   #7
Tokay444
Not always, and many times require re-torquing after a period of time or heat cycles.
The shop manual will tell you whether they need to be replaced, usually with an 'R' designation beside the part number, or if they are reusable. IF they are reusable, there will likely be a value for maximum allowable elongation, but since you didn't measure them before assembly, I would advise you buy new ones, document their overall lengths before assembly, and you may then be able to reuse those ones next time.
Old 11-29-2017, 03:08 PM   #8
I would always recommend new head studs.
Capt Spaulding (11-29-2017), wparsons (11-29-2017)
Old 11-29-2017, 05:03 PM   #9
reebis
reebis's Avatar
Drives: 2020 STI Limited
In the EJ series engines the headbolts are TTY...I have heard of people reusing them with no issues. I'm not sure if the FA's are TTY.
If it were my motor and I had it torn down that far I would just opt for a new OEM set or ARP replacements just for piece of mind.
reebis is offline   Reply With Quote
The Following User Says Thank You to reebis For This Useful Post:
OEM Camber Bolts (Crash Bolts - SU003-02818) dieseldan444 Brakes, Suspension, Chassis 2 07-12-2018 10:06 PM
MotorTrend's Head-2-Head MX-5 MiataRF vs. Toyota86 WorldRallyB FR-S / BRZ vs.... 150 11-22-2017 02:52 PM
BRZ head lights -> JDM 86 head light conversion BRZPDX Cosmetic Modification (Interior/Exterior/Lighting) 6 08-02-2013 11:47 AM
Scion FR-S vs Mazda MX-5 Club Head-to-Head (Review and Video) M-17 FR-S / BRZ vs.... 96 03-05-2013 03:40 PM
Motortrend Head 2 Head: MX5 vs FRS jenzan FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 7 03-01-2013 11:59 AM
