Drives: 2015 Raven FRS
Head Bolts
If pulling the heads off my FA-20 engine are the head bolts re-usable?
#2 |
#3 |
Drives: 2017 BRZ
Look up the fastening procedure for installation. If it's TTY (torque to yield), they must be replaced. I'd replace them regardless or go with studs.
| The Following User Says Thank You to gtengr For This Useful Post: | humfrz (11-29-2017) |
#4 | |
What I said was 1940-50 mechanics. However, after doing a little reading: http://www.acl.co.nz/wp-content/uplo...-Headbolts.pdf http://www.enginebuildermag.com/2001...rque-to-angle/ I would error on the side of caution and figure the OEM head bolts were TTI fastened and use new bolts for your rebuild. Bubba says to ..... screw it and use the same old bolts ...... In reality, if my FR-S's engine needed that much work ..... I'd trade the car in for a new one ....... ![]() humfrz |
#5 |
I have had one local engine builder tell me they are torque to yield. So new bolts it is. And if going new bolts He said stock bolts are not the best and advised just going with ARP bolts. So if needed, ARP it will be.
#6 |
If you're pulling the heads anyway, ARP bolts/studs are cheap insurance.
#7 | |
The shop manual will tell you whether they need to be replaced, usually with an 'R' designation beside the part number, or if they are reusable. IF they are reusable, there will likely be a value for maximum allowable elongation, but since you didn't measure them before assembly, I would advise you buy new ones, document their overall lengths before assembly, and you may then be able to reuse those ones next time. |
#8 |
I would always recommend new head studs.
| The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | Capt Spaulding (11-29-2017), wparsons (11-29-2017) |
#9 |
Drives: 2020 STI Limited
In the EJ series engines the headbolts are TTY...I have heard of people reusing them with no issues. I'm not sure if the FA's are TTY.
If it were my motor and I had it torn down that far I would just opt for a new OEM set or ARP replacements just for piece of mind. |
| The Following User Says Thank You to reebis For This Useful Post: | wparsons (11-29-2017) |
| OEM Camber Bolts (Crash Bolts - SU003-02818) | dieseldan444 | Brakes, Suspension, Chassis | 2 | 07-12-2018 10:06 PM |
| MotorTrend's Head-2-Head MX-5 MiataRF vs. Toyota86 | WorldRallyB | FR-S / BRZ vs.... | 150 | 11-22-2017 02:52 PM |
| BRZ head lights -> JDM 86 head light conversion | BRZPDX | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 08-02-2013 11:47 AM |
| Scion FR-S vs Mazda MX-5 Club Head-to-Head (Review and Video) | M-17 | FR-S / BRZ vs.... | 96 | 03-05-2013 03:40 PM |
| Motortrend Head 2 Head: MX5 vs FRS | jenzan | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 7 | 03-01-2013 11:59 AM |
