Old 11-26-2017, 12:00 AM   #1
ChrisW
Drives: Subie blue 2017 limited
Brake pressure PID?
Has anyone found the PID for brake pressure? I'm hoping to be able to log it with an OBD2 app and not need to get it via USB from a tuned ECU.
ChrisW is offline   Reply With Quote
Old 04-17-2018, 07:37 PM   #2
gcranston
Drives: 2015 Subaru BRZ Limited DGM
I would love to get this working as well. Aim can see it. Has anyone figured this out? OP are you using torque?
gcranston is offline   Reply With Quote
Old 07-23-2018, 07:20 AM   #3
n0thing
Drives: Subaru BRZ
bump
I've logged brake pressure, steering angle and individual wheel speeds using OFT, but reviewing the data and overlaying them on videos takes a lot more work. Ideally I'm looking to do so via Racechrono/HLT/Torque. Or are those values limited to CAN mapping only?
n0thing is offline   Reply With Quote
Old 07-23-2018, 11:52 AM   #4
treedodger
treedodger's Avatar
Drives: 2022 GR86 (was 2013 BRZ)
Harrys Lap Timer (HLT) supports custom PID in their Beta V22 release, but I haven't figured out how to capture brake pressure. HLT V22 will estimate brake pressure from accelerometer data, if a custom PID isn't used.
http://forum.gps-laptimer.de/viewtopic.php?f=48&t=4907
I found this, but not sure how to implement it:
https://forum.autosportlabs.com/view...sc&start=0
Brake Pressure/Position
Offset: 16
Length: 8
Type: Unsigned
Endian: Little
Multiplier: ???
Unit: ???
I have not quite deciphered the brake unit conversion yet. I have seen values of 0-120ish in practice. This is likely limited to just how hard I can press down on the pedal. This may be a position or pressure value.
2022 GR86 / 2013 BRZ
86drivechallenge.com/
treedodger is offline   Reply With Quote
The Following 3 Users Say Thank You to treedodger For This Useful Post:
TofuJoe (07-24-2018), Walldodger (07-25-2018), whataboutbob (02-13-2021)
Old 10-24-2019, 09:46 AM   #5
HSV Guy
Drives: Not a HSV (2017 BRZ)
Bump, anyone been able to get this setup via an OBD dongle? Would like to use this, if possible, with Harry's Lap Timer (HLT).
HSV Guy is offline   Reply With Quote
Old 10-26-2019, 02:23 AM   #6
treedodger
treedodger's Avatar
I never got this to work and those OBD signals I did get were out of sync and HLT tools for fixing this would a waste of time (circa 2018).
I gave up and bought a Aim Solo 2 DL.
Old 07-15-2020, 07:30 PM   #7
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Couldn't read the brake pressure via OBD, but at least was able to read pressed/released.
Better than nothing, at least should be possible to see braking points lap vs lap.
In RaceChrono, I use
0x7E0 for "OBD-II header"
PID 0x221233 for brake pressed/released (Mode 22, PID 0x1233?)
PID 0x22122F for clutch pressed/released
Equation: B / 2.55
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
soundman98 (07-15-2020)
Old 07-16-2020, 01:49 AM   #8
Compelica
Compelica's Avatar
Drives: 86 GT
Equation: B / 2.55
Thanks @timurrrr, how are you obtaining these PIDs? Would be much easier to log them using Torque than pulling Tactrix at times...
Compelica is offline   Reply With Quote
Old 07-16-2020, 03:35 PM   #9
RRslip
Drives: Black BRZ - STX
I take brake pressure from CAN ID 209 (decimal), offset 2, length 1, unsigned, little endian. No equation needed. I think it's in Bar.
RRslip is offline   Reply With Quote
Old 07-16-2020, 05:07 PM   #10
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
I believe you're reading it from CAN directly? Not from OBD-II, which is the topic of this thread.
How to read it from CAN has already been mentioned above.
Which device do you read it through? Can you send it to RaceChrono/HLT via Bluetooth?
Old 07-16-2020, 05:37 PM   #11
RRslip
Offset: 16
Length: 8
Type: Unsigned
Endian: Little
Multiplier: ???
Unit: ???
I thought I would shed some light on the multiplier and unit. I'm using a RaceCapture Track MK2 which does PIDs and public CAN.
https://www.autosportlabs.com/produc...turetrack-mk2/
The Following User Says Thank You to RRslip For This Useful Post:
timurrrr (07-16-2020)
Old 02-13-2021, 07:55 AM   #12
Compelica
Compelica's Avatar
Drives: 86 GT
Just wanted to bring this up - the OBD Fusion app with the extended parameters has the brake pressure PID, which works well but the app is a little slow in responding. Would have preferred to port the PIDs to Torque which has much more flexibility, but at least there's the option for us FRS/86/BRZ owners.
The Following User Says Thank You to Compelica For This Useful Post:
timurrrr (02-19-2021)
Old 02-17-2021, 02:03 AM   #13
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Do they show which PID they use?
Also, which car did you test it on? FR-S, BRZ or [GT]86?
Those "extended parameters" are typically manufacturer-specific, and they consider Scion, Subaru and Toyota to be very different manufacturers.
Old 02-17-2021, 04:36 AM   #14
Compelica
Compelica's Avatar
Drives: 86 GT
I doubt it is different - I expect it to be universal across the models, given that the tunes for the 3 models are basically the same apart from some regional differences. For example my car is a JDM GT86 running a tune for Australian 86/BRZs with the OBD Fusion app set as a Scion FRS.
On getting the actual PID addresses and formula - unfortunately that's hidden away as getting those extended PIDs is a paid feature. You can only select it but not manipulate how it is calculated since it could be easily copied out.
On the other hand if we had someone able to do some RE we can probably make some progress...
CAN bus PGN for steering angle and brake pressure RMP Software Tuning 0 04-09-2015 01:55 AM
best tire pressure gauge (tire pressure question) steveholt Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 03-21-2015 10:27 PM
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate PineappleFriedRice Transmission and Driveline 0 11-08-2013 04:54 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
