Old 11-21-2017, 06:47 PM   #1
J41v33
Drives: fr-sexy
Dirty Clutch Fluid, leaking slave cylinder?
I flushed my clutch fluid a few months ago because the clutch pedal was feeling abnormal. The clutch fluid was kinda dirty but it was the oem clutch fluid so that was expected. Today I checked the clutch fluid, and it was already really dirty
is this a sign of a failing slave cylinder? If it makes a difference, i had the the clutch pedal adjustment done, but after driving it for a year i moved it back to the stock position. Could that have caused some dirt trapped in the lines to move up into the reservoir since there is now full movement of the plunger in the slave cylinder?
J41v33 is offline   Reply With Quote
Old 11-21-2017, 07:40 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
If it was a failing slave cylinder you'll see the mess.
This is just my guess, the slave casting is not fully cleaned when installed from the factory. Should it affect performance? I don't think so. But you know o rings and what nots are the fail points.
As for the pic, that's normal. that dirt sticking to the grease used for the pivot fork.
If it bothers you that much you can drain it and fill it. It won't take that much or that long.
Old 11-21-2017, 08:38 PM   #3
ermax
ermax's Avatar
I’ve seen a failing slave or master cause contamination before. The rubber breaks down and has to go somewhere. Do you have a mess near your clutch pedal?
Old 11-21-2017, 09:36 PM   #4
humfrz
Oh, I'd just flush it again and as long as the clutch works proper, I wouldn't worry about it.
humfrz
Old 11-21-2017, 09:41 PM   #5
J41v33
Drives: fr-sexy
No mess at the clutch pedal, just weird that it would get dirty so fast. Thanks the help guys
Old 11-22-2017, 12:08 AM   #6
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Maybe the cap is not sealing correctly?
Old 11-22-2017, 12:16 AM   #7
Ultramaroon
not playing cards
Ultramaroon's Avatar
Oh, it's fine. Would need to disassemble and clean both cylinders to get a totally clean fill. Otherwise a bit of the old stuff always remains and contaminates the new.
The clean plastic at the bottom of your reservoir is clearly visible. No worries.
jcw99 (11-28-2017)
FS: Agency Power SS clutch line, OEM slave cylinder - SOLD Agent_D Transmission and Driveline 2 08-01-2017 07:02 PM
BNIB Subaru OEM 3/4" Clutch Slave Cylinder e1_griego Transmission and Driveline 4 11-12-2016 09:16 PM
FS: OEM Clutch Slave Master Cylinder MicheleAbbate Transmission and Driveline 3 05-09-2016 04:48 PM
Clutch Slave Cylinder KAR Southern California 4 08-08-2015 09:25 PM
OEM Clutch Slave Cylinder $20 shipped SlowCone Transmission and Driveline 0 04-25-2015 05:07 PM
