Old 11-20-2017, 10:28 PM   #1
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
Aftermarket headlights - Do they telescopic like OEM?
Hey guys, I have a BRZ limited and I love the feature it has for OEM headlights, where I have a setting from 0-5 for level of angle for the headlights. I'm not looking into aftermarkets by any means, but I was curious if the aftermarkets allow for this function? For example, spec d's or anything like that? Does anyone have a set on their brz or does anyone have any knowledge if they are able to?
Setgo is offline   Reply With Quote
Old 11-20-2017, 10:50 PM   #2
ryoma
ryoma's Avatar
FWIW, the BRZ projectors are one of the best out there so it would be a shame to swap them out for a lesser quality one (most aftermarket headlights are crappy, unless you retrofit it yourself). also, I believe the motor is on the actual headlight housing. it's been a while since I manually adjusted my headlights but I believe it was behind the housing.
Old 11-20-2017, 11:00 PM   #3
Setgo
Setgo's Avatar
hmm so I'm guessing then, if someone wanted aftermarket headlights on their brz, and wanted that function, they would somehow have to retrofit the motors, etc. Wow haha. I understand if someone had an frs and wanted to change their headlights. I say that because it doesn't come close to the BRZ as far as projection and clarity.
WTB - Aftermarket Headlights Xplicit Canada Classifieds 1 05-23-2016 10:50 AM
Aftermarket Headlights DCStorm Cosmetic Modification (Interior/Exterior/Lighting) 20 07-25-2015 11:51 PM
Telescopic Steering Wheel - IHMO Motopythons BRZ First-Gen (2012+) — General Topics 34 10-27-2014 02:06 PM
Any Aftermarket Headlights? blugbox Cosmetic Modification (Interior/Exterior/Lighting) 6 07-02-2013 06:05 PM
where's the aftermarket headlights? abutterman Cosmetic Modification (Interior/Exterior/Lighting) 22 03-23-2013 10:09 PM
