Old 11-19-2017, 07:35 PM   #1
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
How to identify if car has BRZedit/Tactrix Tune?
Trying to figure out if my car was previously tuned with these programs. It's for sure not ECUTEK because i got the error message:
"Error Message: Programming has failed.This ECU may need to be programmed again before the car will start.Error was: Security Access: 36 exceedNumberOfAttempts"
I'm also certain it's not tuned by OFT because OFT can't even READ the car right now. Car also does not have an existing ECUTEK license.
Is there a way to identify which program was previously used? I'm going to be reaching out to different tuners this week to see if they can remotely help but it's going to be a long shot.
Any BRZedit tuners or Tactrix users have input? Thanks.
Decimus is offline   Reply With Quote
Old 11-19-2017, 08:11 PM   #2
ermax
ermax's Avatar
ECUFlash has the ability to compare two ROMs. You could use a Tactrix cable to dump the current ROM and then compare it to an OEM ROM to see if there are any differences.
The Following User Says Thank You to ermax For This Useful Post:
Decimus (11-22-2017)
Old 11-20-2017, 12:06 AM   #3
steve99
Ok ill assume you have ecutek cavle and tried to write.
So yes you can asume its not ecutek tune :-)
The only other common tune system that locks ecu for read\write is brzedit.
Oft and tactrix\ecuflash do not lock ecu
Try doing a query ecu with ecutek or oft or tactrix ,ecuflash ecu info read it will likely read the calibration id. If it does it confirms conmection to ecu.
You can pretty well assume its brzedit tune if ecutek wont write to it.
Hopefully ecutek didnt burn you licience trying to write to the locked ecu.
Your can either replace ecu , or find someone with brzedit to overwrite it. Or get onto ecutek in england they can crak the brzedit lock for you, but they might charge not sure, they will need remote access to your pc
The Following 2 Users Say Thank You to steve99 For This Useful Post:
Decimus (11-22-2017), humfrz (11-20-2017)
Old 11-20-2017, 12:08 AM   #4
steve99
Wont work brzedit locks ecu, tactrix wont read or write to ecus with brzedit of ecutek locks
Old 11-20-2017, 10:34 AM   #5
ermax
ermax's Avatar
Thanks for the clarification.
Old 11-22-2017, 01:48 AM   #6
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
@steve99 you are once again the super guru to this. I contacted ecutek UK and they issued me another license since my previous attempt to write over the existing tune failed & ate my license.
Im scheduled to have them remote access my computer 6am Thanksgiving morning (im so glad they dont have Thanksgiving lol)
Hopefully they are able to solve all my issues. Its been a real headache trying to figure out this tuning thing. Ill report back if ecutek is successful
Old 11-22-2017, 03:18 AM   #7
steve99
hopefully ecutek can still unlock the brzedit locks, as brzedit guys altered their locking technique a while back. will be interested to hear if they are successful or you have to send ecu to them for full SH boot mode reset of ECU.
Old 11-22-2017, 03:50 PM   #8
Decimus
BAE
Decimus's Avatar
Drives: Asphalt FRS
Yeah i hope they are successful. The tune dates back at least 1.5-2 years. It'll also be interesting if the car wasn't tuned via BRZedit... crossing my fingers for tomorrow morning!
Old 11-24-2017, 10:06 AM   #9
steve99
mate if no luck with ecutek.
your other options would be
replacement ecu they go for about $90-$130 usd on ebay
swap procedure here
http://www.ft86club.com/forums/showthread.php?t=102810
or send it to me and ill reflash it to stock for you might get expensive with freight though
ECU Tune with Tactrix using OTS Map for Perrin BigMAF 3" rhino Software Tuning 4 11-29-2017 11:39 AM
Tactrix open port 2.0 e tune? ort895 Software Tuning 1 04-02-2016 05:52 PM
Any places in Atlanta that can tune via tactrix? glorydays Southeast 1 06-13-2014 11:58 AM
Laptop + Tactrix cable + BRZEdit personal - $400 Dodzilla Engine, Exhaust, Bolt-Ons 5 02-14-2014 04:30 PM
Hallman Pro MBC, Tactrix Cable, BRZEdit jamesm Engine, Exhaust, Bolt-Ons 3 02-11-2014 02:33 PM
