Old 11-18-2017, 03:08 PM   #1
StraightOuttaCanadaEh
Wes
right hip pain while driving
Okay so like 10 minutes into my drive, I start getting pain in my right hip that shoots down to my knee. I'm 32 so I'm pretty sure it's not OA. I noticed that the way I sit is kind of with my pelvis rotated slightly inward, which puts pressure onto my right hip, but it's the position I assume naturally to achieve a proper right foot position. What I'm trying to find out is if it's 1. Position of the pedals. 2. Just the way I sit. 3. Lack of support from the seat.
Has anyone encountered this issue before? Really takes away from the enjoyment of driving cause now I spend the whole time shifting around, adjusting the recline position, distance to the pedals, but nothing seems to be working. If I put my leg/foot in a position where the pain goes away, it causes the foot-pedal connection to feel awkward. Would appreciate any useful input. Thanks
Old 11-18-2017, 03:17 PM   #2
JD001
JD001's Avatar
Drives: Subaru BRZ
I think it's the way you are sitting. Do you drive with both hands on the wheel or rest your elbow (door or centre console) as this can have an influence on your back/hip/knee relationship?
Old 11-18-2017, 03:21 PM   #3
Wes
I rest my elbow. You think I should have both hands on the wheel?
Also I can't figure out where my heel should be, as this seems to make a big difference as well. Do you rest it between the brake and throttle or directly in front of one of them?
Old 11-18-2017, 03:36 PM   #4
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
Sounds like you're putting tension on that sciatic nerve from improper posture. I'd advise sitting more straight without tilting your pelvis. You can get into a proper driving position without unnatural or lazy hip rotation.
If you find its a common occurrence even after fixing your posture, I'd suggest taking a closer look at your muscles. Haha
MS, CSCS, TSAC-F, CPT
Old 11-18-2017, 03:42 PM   #5
Wes
No I've had sciatic pain before from sitting on my wallet too much and I know what that feels like, and this isn't it. This feels like tension on the lateral tensor muscle at the hip. It connects to the right side of the knee and that's where I feel the pain as well. And the position of the hip, like I said, is dictated by my right foot. It just feels most natural to sit this way and maintain equal distance to the gas and brake
Old 11-18-2017, 03:47 PM   #6
JD001
JD001's Avatar
Drives: Subaru BRZ
Short answer: Yes. Bad posture when driving will screw with your back and hip.
Your clutch foot can be rested on the rest when not changing gears. Your throttle foot will shuffle between the gas and brake pedal. The movement between the throttle and brake should be an easy rotation.
Old 11-18-2017, 03:49 PM   #7
Wes
Seems to be what I'm doing. I've been doing some low and heavy squats at the gym, maybe that stirred the hornets nest a bit. Thanks for your replies
Old 11-18-2017, 03:52 PM   #8
mrspindlelegs
Drives: 2014 Scion FR-S Monogram Series
Do you drive with your wallet in your back pocket? If yes, is it the right pocket? I ran into that problem and taking the wallet out of my right back pocket helped a lot with reducing discomfort in the right hip.
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit.
Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg
Semi-truck crushed it on 1-1-2023.
mrspindlelegs is offline   Reply With Quote
Old 11-18-2017, 03:56 PM   #9
JD001
JD001's Avatar
Drives: Subaru BRZ
Oh, one more thing: reduce the size of your wallet.. spend some cash to get into a reasonable size/weight and relocate to one of your front pockets.
Old 11-18-2017, 03:56 PM   #10
weederr33
weederr33's Avatar
Ah well then posture has to be it. And if you're hitting them gym that could exacerbate it. Especially if you're not stretching or foam rolling.
Old 11-18-2017, 03:58 PM   #11
humfrz
Now, I wouldn't be too sure of that .........
I have a couple of quick, inexpensive and easy things for you to try.
* cut a seat pad (just to fit the center bottom section) out of high density foam (like back packers sleep on) and place it on the seat. The cushioning just may keep your butt bone from pushing on that nerve.
* get an inexpensive seat wedge and cut it in half (long ways) and place it between the small of your back and the seat. This will shift your back slightly and maybe relieve the pressure on the troubled nerve.
humfrz
Old 11-18-2017, 04:29 PM   #12
Wes
Nope my wallet is in the cupholder. Never on me
Old 11-18-2017, 04:31 PM   #13
Wes
humfrz
I had a feeling I would get a comment about OA from you! Haha. I'll try the seat foam thing. Thank you
Old 11-18-2017, 04:32 PM   #14
weederr33
weederr33's Avatar
humfrz
As a strength coach and personal trainer, I'd suggest this too! Or building more butt mass
The pain of bolt-on life SCQTT Off-Topic Lounge [WARNING: NO POLITICS] 25 03-17-2017 09:05 PM
Car Seat Pain Amourii Issues | Warranty | Recalls / TSB 40 06-14-2016 11:26 PM
Is my pain normal? boredom.is.me Scion FR-S / Toyota 86 GT86 General Forum 22 04-15-2013 06:57 AM
