Old 11-15-2017, 07:29 PM   #1
Terruko
Terruko's Avatar
Brake light comes on sometimes when I brake
My brake fluid is low, maybe that’s why. My question is, can I just put some brake fluid in it and call it a day or do I have to remove the old brake fluid and put new one in it?
Terruko is offline   Reply With Quote
Old 11-15-2017, 07:41 PM   #2
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
Proper terminology and nomenclature is important.
You have three brake lights that should illuminate when depressing the brake pedal. Are two of them not working? Brake lights do not normally have brake fluid in them, that could be the cause of the intermittent illumination of one and the failure of the other two and could also explain the low level in the brake-fluid reservoir if your brake lines are indeed also hooked to the brake lights somehow.
I'd add brake fluid to the reservoir just to make sure. No need to drain and bleed unless your brakes are mushy and the brake lights bubble when you get on the brakes. Brake fluid can be real hard on plastic, too, so keep an eye on the brake lights for leaks.
PetrolioBenzina is offline   Reply With Quote
The Following 3 Users Say Thank You to PetrolioBenzina For This Useful Post:
Cole (11-15-2017), mav1178 (11-17-2017), sgtcarrot (11-17-2017)
Old 11-15-2017, 07:53 PM   #3
humfrz
If it's the emergency brake light coming on ....... I'd suggest you just add some brake fluid .....
humfrz
Old 11-15-2017, 08:09 PM   #4
PetrolioBenzina
Drives: 17 86
humfrz
Or the traction-control light. OP is unclear.
Old 11-15-2017, 08:10 PM   #5
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Most usually brake fluid being on the low side means that it has migrated out to the calipers to make up for the brake pads being worn away.
May want to check on the pad thickness currently.
Changing those and pushing the fluid out of the calipers would move the "lost" back into the reservoir.
As long as you're farting around with it anyway, bleed in new fluid too.
The Following 4 Users Say Thank You to bcj For This Useful Post:
Cole (11-15-2017), ermax (11-15-2017), Tcoat (11-15-2017), Ultramaroon (11-15-2017)
Old 11-15-2017, 09:06 PM   #6
ermax
ermax's Avatar
For sure do not top it off without checking the pads first. If you top it off and then later find out the pads are gone, you will need to take fluid back out or else it will overflow and make a mess when you put the new pads on. As bcj says, it’s usually an indication of pads being worn. If the pads are good and it’s low then it’s getting lost somewhere else. Check around the brake pedal for fluid. If there is fluid there then it’s the master cylinder. Also check the inside of your rims for a mess because a leaky caliper will often drip onto the rims and get slung around.
The Following 2 Users Say Thank You to ermax For This Useful Post:
Cole (11-15-2017), Tcoat (11-15-2017)
Old 11-15-2017, 09:11 PM   #7
Terruko
Terruko's Avatar
humfrz
Oh, it is the e brake light. I took the car to the dealership for it’s 60k service on monday and in the paper I got it said the brakes were fine, but last time I took it to get an oil change it said this.
I’ll add brake fluid and see if it helps, thanks everyone.
Old 11-15-2017, 09:18 PM   #8
Do NOT just add fluid. It went someplace. If your brake pads were down two visits ago they didn't magically regenerate this trip. They are worn to the point your fluid is low enough to trigger the warning light and adding fluid isn't going to fix the root cause. Take it back and have them actually look at the pads this time.
winstonscifi (11-15-2017)
Old 11-15-2017, 09:18 PM   #9
ermax
ermax's Avatar
Wow, your fluid is low yet the dealership said your brakes were fine. I think it’s time to go to another dealer.
Old 11-15-2017, 09:59 PM   #10
humfrz
Well, for sure your brake pads are getting down there.
Adding fluid might keep the light from coming on, but, it won't add to the pads.
However, I doubt that they are now down below 4 mm from 7-8 mm, just 7,500 miles ago.
Bubba says they are most likely good for another 5-10,000 miles.
I reckon @Ultramaroon would recommend all new pads, rotors and calipers ..... he always goes first class.
@Tcoat recommends new pads ...... because he's in the brake business and most likely gets some sort of kickback ....... somehow ....... it's a balance of trade thing.
humfrz - senior master brake specialist - retired..........
Ultramaroon (11-15-2017), winstonscifi (11-15-2017)
Old 11-15-2017, 10:15 PM   #11
PetrolioBenzina
Drives: 17 86
The light is telling you there is a fault with the brake system. Get an actual answer.
Old 11-15-2017, 10:18 PM   #12
ToySub1946
ToySub1946's Avatar
Drives: 15FRS, 05MustangGT, 85Toyota truck
Attached shows new and minimal specs for all brake linings. (From 2012 BRZ service manual, taken from this site).
ToySub1946 is offline   Reply With Quote
The Following User Says Thank You to ToySub1946 For This Useful Post:
humfrz (11-15-2017)
Old 11-15-2017, 10:31 PM   #13
ToySub1946
ToySub1946's Avatar
Terruko,
"My question is, can I just put some brake fluid in it and call it a day or do I have to remove the old brake fluid and put new one in it?"
This is >poor advise< from me, but here it is. I'd throw caution to the wind. Add a minimal amount of new brake fluid to it's reservoir (like 1 to 1 1/2 ounces only), just enough to make that instrument cluster brake light stay off.
You don't want to fill to the max level, as later, when new pads are needed level will then go up by itself.
Being a former auto tech, I firmly believe in giving her only what she begs for. Never know, you might just decide tomorrow to trade her in.
Attempting to read what the tech wrote...appears left front disc brake pad has 4mm remaining. Minimal would be 1.5mm as it's limit. So that one needs to be checked again, next service. Possibly a New Year's Resolution. Have a nice Holiday season.
The Following 3 Users Say Thank You to ToySub1946 For This Useful Post:
Cole (11-15-2017), humfrz (11-15-2017), Terruko (11-16-2017)
Old 11-15-2017, 11:04 PM   #14
Ultramaroon
not playing cards
Ultramaroon's Avatar
Calipers?
I'll admit I'm a sucker for fresh rotors, though.
Cole (11-15-2017)
DIY:Valenti 3rd/4th Brake Light Mod-Separate Brake light Triangle-2 Options -Video continuecrushing DIY (Do-It-Yourself) Guides 44 11-23-2020 06:17 PM
DIY: Valenti 4th brake light wiring for no blink brake light. (Triangle) BirdTRD DIY (Do-It-Yourself) Guides 17 11-06-2017 08:42 PM
Valenti 4th brake light vs Valenti Style brake light? JGalp Electronics | Audio | NAV | Infotainment 9 03-24-2016 05:48 PM
FS: FRS OEM E-Brake (Emergency Brake) Hand Brake Boot CamryDS Interior Parts (Incl. Lighting) 0 06-24-2013 11:26 PM
Redline360: Brake Lines, Brake Rotors, Brake Pads for BRZ/FRS Redline360 Brakes, Suspension, Chassis 12 01-05-2013 10:20 PM
