Old 11-10-2017, 06:16 PM   #1
drz400dude
4th brake light question
I am driving a little ways to buy a valenti 4th brake light off a guy. Is there a quick way to test to make sure it works before I buy, besides installing it?
drz400dude is offline   Reply With Quote
Old 11-10-2017, 06:21 PM   #2
StanBo
StanBo's Avatar
Drives: 2018 BRZ ~ 1992 Miata
12v power supply that runs off 110v and a pair of alligator test leads?
StanBo is offline   Reply With Quote
Old 11-10-2017, 07:04 PM   #3
drz400dude
I was thinking touching the wires up to the battery, but I just wasn't sure if the brake lights ran off 12v or if there was something different in the circuitry in the car. Or which wires. From the pic there seems to be multiple wires. I haven't messed with the 4th BL yet so I'm not sure how it works.
Old 11-10-2017, 07:09 PM   #4
drz400dude
This is what the wiring looks like...
Old 11-10-2017, 07:48 PM   #5
StanBo
StanBo's Avatar
Without reference I would think tapping them to the battery would work. It is 12v as what they should be getting when operated.
Old 11-10-2017, 08:06 PM   #6
HachiRolle
Drives: 2017 Toyota 86
Just a heads up, that’s not a Valenti.
HachiRolle is offline   Reply With Quote
Old 11-10-2017, 10:05 PM   #7
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Yes, 12v direct from the battery will work with the proper polarity.
And also, Hachi is right, it's not Valenti, it's GCS. Worth at least half as much as Valenti
sharpsicle is offline   Reply With Quote
Old 11-10-2017, 10:42 PM   #8
wolffbite
Just the tip
wolffbite's Avatar
Drives: 2017 DGM BRZ
Yup, smoked GCS not a valenti.
Does it come with the rest of the wiring harness? Otherwise you will have to cannibalize your stock reverse harness and repin. All guides online for a new unit with the harness are already pretty bad, so it might be more trouble than it's worth.
wolffbite is offline   Reply With Quote
Old 11-11-2017, 12:01 AM   #9
drz400dude
Thanks for the heads up everyone. I just saw the "V" shape and didn't think twice. You guys are def right. I wonder if this guy knew and was trying to BS or what.
Valenti Third Brake light question VoltsFRS2013 Cosmetic Modification (Interior/Exterior/Lighting) 5 09-25-2017 10:47 AM
GCS reverse/third brake light question StraightOuttaCanadaEh Cosmetic Modification (Interior/Exterior/Lighting) 16 08-25-2017 08:03 AM
HELP! 3rd Brake Light Question!?!? WOODNUTS_86 Cosmetic Modification (Interior/Exterior/Lighting) 1 09-30-2016 11:10 PM
Question to those that have removed 3rd brake light IronDuke Cosmetic Modification (Interior/Exterior/Lighting) 5 02-16-2016 11:35 PM
Question on fog/3rd brake light blinking fx35s Cosmetic Modification (Interior/Exterior/Lighting) 14 01-26-2014 01:32 PM
