Old 11-03-2017, 01:47 PM   #1
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
Question Invidia line-up
Okay so question for all the timers/experienced guys
Here is what I am getting for my FRS in the next few months
Invidia Catless Header EL
Invidia Over Pipe
Invidia N1 (package deal with Front pipe)
OFT tuning tablet (I will be running stage 2 EL 95)
Injen Cold air Intake w/heat shield
Hotchkis strut tower brace
Do I need o2 spacers as well?
How much gain (if any) would I be seeing with this line up? I am bone stock right now.
And after these mods , what do you guys suggest me doing next?
Thanks for the support
SHOGUN66 is offline   Reply With Quote
Old 11-03-2017, 02:06 PM   #2
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
I hope you like loud, because that setup may be one of the loudest set ups on the stock front pipe i can think of short of a muffler delete. If that's what you're after, this would be a quality set up.
As far as O2 spacers, they won't be necessary, as the OFT stage 2 tune removes any O2 sensor check engine light that is associated with going catless.
I would skip on the Injen intake, unless you are looking forward to fiddling with your MAF scale using the OFT. I had one for about a year and even though I was able to eventually tune the MAF scale for higher RPM in, the heat soaking and high IAT, paired with low RPM bogging led me to returning to the stock airbox with a drop-in filter and smooth intake elbow. This set up felt much better, and the car ran much better. You can also see this in my car journal (click the picture in my sig).
As far as future mods, that would be up to you. I would get used to the new power and maybe feel out what else is lacking for you in other things such as suspension and interior.
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
Teseo (11-04-2017)
Old 11-03-2017, 02:28 PM   #3
Azzudien
Drives: 2017 Series Yellow BRZ
Why don't you just go with this from Counterspace garage. Everything you are looking for in a proven package
http://counterspacegarage.com/csg-power-gas-gt86.html
Azzudien is offline   Reply With Quote
Old 11-03-2017, 03:14 PM   #4
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
To be honest, your proposed setup doesn't make much sense. (That's not a dig, just a learning opportunity!)
FIRST: Read this - http://www.ft86club.com/forums/showthread.php?t=81493
SECOND: Read below
The over pipe offers next to no gain until you're hanging out by 200whp. Your front pipe is what you need to consider using an aftermarket component for. Leave your overpipe alone, divert these funds to either a quiet catback, or a catted and resonated, or dual resonated front pipe.
The N1 is incredibly loud with anything but a stock header. If you want reasonably priced and less loud, the Q300 is a good choice. If you want it louder than the Q300 but not deafening, the Dezon 2.5" or Perrin 2.5" catback are good choices, (coming from someone who very rarely suggests Perrin products... The Dezod is a bit louder.)
The Injen intake is garbage. You will gain very little power, if any, and your intake charge will be hotter. The stock intake is actually very good, think about it! Subaru and Toyota pooled financial and engineering resources to build this car, They didn't say, 'ah yes, we'll make it about 80% as efficient as we can so the aftermarket can sell volumetric efficiency for $300 a pop.' They have some pretty strict economy standards to meet, so you had better believe the intake is GOOD. If you want some nice sounds, you can grab a silicone intake tube, and a dry flow panel filter. The gains will be comparable at less than half the price, which by the way, are still pretty minimal.
The suggestion from @Azzudien is a good one, as the ACE header is the best on the market, period, and Ecutek is definitely the way to tune, the Delicious tunes are great, and MXP makes high quality catbacks, albeit a bit heavy. ( I run one and it sounds fantastic, and looks great after 2 years of New England winters.)
The 'common package' that I tend to suggest is:
JDL header, (it's the best for the money, they even offer an EL version if you're not into rumble,) JDL Ultra quiet front pipe, Ecutek cable and license with either a Moto-East or a Delicious tune, and a catback to taste. Your car will be substantially louder with just the header and front pipe. I think it's best to start with this because you can decide if you want it a little louder or a lot louder when you buy the catback.
If you feel like balling out of control, the ACE header is the best header on the market, and is worth every cent.
I hope this post was helpful! Again, I didn't mean to poo-poo your proposed build, but hopefully steer you in the direction to a better experience and performance.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 11-03-2017, 03:18 PM   #5
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
What kind of gains would I be looking in contrast to my list. If I decided to get it, I can’t find any literature.
Thanks for all the help!
Old 11-03-2017, 03:24 PM   #6
Azzudien
Tons of stuff on this forum from CSG about this combo.
http://www.ft86club.com/forums/showthread.php?t=88696
http://www.ft86club.com/forums/showthread.php?t=121460
I imagine most of the forum vendors are at SEMA this week, but I would hold off on our purchase until you talk to them next week.
Old 11-03-2017, 03:24 PM   #7
JazzleSAURUS
Research, my friend: http://www.ft86club.com/forums/showthread.php?t=80609
Old 11-03-2017, 03:26 PM   #8
JazzleSAURUS
You can use google to search on FT86club specifically.
In google, punch in "site:ft86club.com/forums whatIWantToSearchFor"
Replace whatIWantToSearchFor with...for example.... Ace Header, and you're now wildly self sufficient.
Old 11-03-2017, 03:44 PM   #9
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
SECOND: Read below
Wow! I really appreciate this ! You opened my eyes !
I am fairly new to the scene and this for sure helped me it , and I appreciate it !
Old 11-03-2017, 04:02 PM   #10
JazzleSAURUS
You're welcome. If you can find a local FT86 enthusiast chapter on facebook it should be pretty easy to get some ride alongs in different setups, and hear different exhausts before you buy.
I also realize I cut up your Invidia idea pretty bad in that post, not intentional! My forester is running Invidia products from the header back. They are good quality for the money, and I think the Q300 is an awesome CBE for these cars for the money, and would likely fit your intended goals pretty well.
Old 11-04-2017, 12:17 AM   #11
NRXRaptor
In my humble opinion, your original idea is pretty good. I think the only thing I'd do is ditch the intake and use that money for a front pipe. If you are doing the work yourself you might as well remove the over pipe along with the headers, as the over pipe is a huge bitch to remove. The only thing is going with invidia and the n1 catback will make your car stupid loud
NRXRaptor is offline   Reply With Quote
Old 11-04-2017, 01:35 PM   #12
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
After these mods, I suggest you get this:
https://www.amazon.com/Mpow-Reductio.../dp/B01L1U9L5W
The Following User Says Thank You to mav1178 For This Useful Post:
Teseo (11-04-2017)
Old 11-04-2017, 04:14 PM   #13
SHOGUN66
SHOGUN66's Avatar
Drives: Scion FR-S
I laughed out loud hahaha that was good!
cold air intake, engine, exaust, tower brace
Help! Brake line leakage after steel braided line install. ysu Suspension | Chassis | Brakes -- Sponsored by 949 Racing 26 02-09-2020 10:38 PM
**INVIDIA** >>SUPER SALE THREAD<< - Invidia N1 - Invidia Q300 - Invidia Front Pipes - FT-86 SpeedFactory Engine, Exhaust, Bolt-Ons 629 12-11-2016 09:21 PM
FS: Invidia Catless Front Pipe/ Invidia Q300 Exhaust Parts timmydatooth Engine, Exhaust, Bolt-Ons 27 04-04-2016 09:46 AM
Invidia Q300 catback & Invidia catless front pipe: 2015 Subaru BRZ WhenzLunch Engine, Exhaust, Transmission 5 02-09-2016 10:18 PM
Invidia N1 SS Catback, Revworks UEL Headers(Brand new), Invidia Front Pipe; &&&MOREEE brzadmir Engine, Exhaust, Bolt-Ons 20 12-23-2013 10:34 AM
