Old 10-28-2017, 11:32 AM   #1
azynneo
Simple offset question
The more negative the offset the more poke right? So in essence it gives the illusion of a wider wheel. If this is the case, would a 9.5 -15mm be equivalent to a 10.5 +10? Or an 11+23m
azynneo is offline   Reply With Quote
Old 10-28-2017, 11:44 AM   #2
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
More negative moves the outside edge of the wheel further away from the hub, yes.
And the outer edge of those three wheels will end up in about the same place. (With my quick guestimation math)
*edit* waaaayyy out. Are you going for the super Mario Cart look, our are these just hypotheticals?
Twinz is offline   Reply With Quote
Old 10-28-2017, 12:11 PM   #3
azynneo
Ya me and yoshi are a team. Jokes aside, pandem rocketbunny.
Old 10-28-2017, 07:39 PM   #4
swarb
Yes, more negative more poke.
No, divide that in half because half of the wheel is on the inside and half is on the outside.
Offset is from the center line.
9.5 -15 is roughly equal(on the outside) to a 10.5 -3(or -2)
9x +0 = 10x +12
9.5 +34 = 10 +40
so 12mm(1/2 inch) for 1 inch width change
and 6mm (1/4 inch) for 1/2 inch width change
New to Tuning... Simple Question cpnslow Software Tuning 21 10-08-2014 11:10 PM
Simple frs coolant question Young_makaveli Engine, Exhaust, Transmission 24 12-25-2013 04:42 PM
Simple rear badge question Bg8780 Cosmetic Modification (Interior/Exterior/Lighting) 7 02-28-2013 12:51 AM
A not so simple question. Asterisked Accolade Tracking / Autocross / HPDE / Drifting 10 01-18-2013 08:40 PM
Simple Question! Spencer Strayer Scion FR-S / Toyota 86 GT86 General Forum 0 09-09-2012 06:53 PM
