Drives: Vroom
FS CA: 1986 TOYOTA AE86 Levin RHD
Up for sale is one of the cleanest and professionally prepared AE86 you'll find.
1986 AE86 Levin (RHD) See pictures here https://flic.kr/s/aHsm5N6GLT Car was legally imported in 2015 and have all import documents for a Federal Legal vehicle. Car has not been CARB certified, so can not use it as a street car in California. The car was originally built in Japan as a club/track day car. The chassis is extremely clean and handling was well sorted in Japan. After I imported into US, I upgraded the engine to a 20V Blacktop, no expense was spared in this build. The car is super light and great fun to drive, it is THE best handling AE86 i've ever driven. Chassis has about 59000 miles ! Car is located in Los Angeles area, California. Price: $18,500 *well over $40k spent on the import of the car and the subsequent build, take a look at the parts list below. This car is perfect addition to your collection while having a blast at track days ! Contact me at: randao85@gmail.com Or call 626 922 9378 Randy List of modifications: Body: Run Free Front Bumper/ Side Skirts TRD Rear Spoiler J-Blood Carbon Vented Hood FRP Side Mirrors Wise Square Crystal Taillights Chassis: Volk TE37 Wheels Front Cusco Coilover Conversion Rear Tokico HTS Short Stroke Shock with GAB Spring Winmax ARMA Sport AP2 Front / Rear Brake Pad Project Mu SCR Pure Plus 6 Front Rotor Dixcel PD Rear Rotor *Brake pad/rotor has less than 1000 miles on them Endless RF-650 Brake Fluid Front / Rear Tower Bar Chassis Riveting Full Safety21 7-Point Roll Cage GT-V steering rack (installed in Japan) Transmission 5speed transmission TRD 1.5way LSD Cusco Transmission Mount T3 Short Shifter Toda Fly Wheel (Ultra Light Weight Chromolly) Toda Competition Clutch Engine Blacktop AE111 4AGE 20V Motor Haltech Platinum Sprint 500 ECU (Battlegarage) Innovate MTX-L Wideband O2 Sensor Tweaked Full Engine Harness (Battlegarage Spec) Chassis Wiring tucked Toda Valve Spring Kelford 194-X (MRP Spec Highlift Camshaft) Toda Exhaust Cam Gear SQ Racing 70mm Velocity Stack Toda 0.8mm Metal Head Gasket (11.5:1 compression ratio) Silkroad 4/2/1 Header Denso Fuel Pump RC Blueprinted Fuel Injectors Martellius D-Mac Special 63mm Underaxle Full Exhaust System (Slip on joints) Individual Coils on Plug Conversion (Toyota 1NZ Coil) MRP Baffled Competition Oil Pan New OEM Timing Belt/Hydraulic Tensioner/Bearing Tensioner/Water Pump/Oil Pump Cusco Engine Mount SQ Racing Coolant Conversion Kit Electric Radiator Fan (controlled by Haltech ECU) SQ Racing Distributor Block Plate (No modification to firewall) SQ Racing Coil On Plug Mounting Plate Koyo Radiator Optima Yellowtop 51R Battery Battlegarage Oil Cooler Kit (Earls Oil Cooler) MRP Oil Filter Sandwich Plate Turbosmart Fuel Pressure Regulator Interior Interior is stripped and painted with sound deadening removed Rare uncracked dash Full center console is retained OEM door panel in excellent condition Power windows works flawlessly Tillet B6F FIA Certified Racing Seat (Driver side) Bride Brix (Genuine) Passenger Semi-Bucket Seat Razo Shift Knob Drift BUtton Takata 6 Point Racing Harness (FIA Certified) Nardi Deep Dish 330mm Steering Wheel Custom Machined Hub Spacer Defi 80mm Tachometer with Shift Light |
Drives: 2013 Hot Lava FRS
Can you please use NSFW tags in the future please? Thank you. Had to make a bathroom trip because of this post. GLWS
| The Following 2 Users Say Thank You to Slammillionaire For This Useful Post: | Crashdummy (10-16-2017), Takumi788 (10-17-2017) |
IG thomas50shades
Drives: ISO: BRZ
Make friends with someone in Florida and you can get it plated. Probably Washington and/or Oregon as well (I forget who easy it is up there).
| Corolla Levin AE86 VS Toyota 86 | tinma | FR-S / BRZ vs.... | 3 | 07-29-2015 07:44 PM |
| 1984 Toyota Corolla Levin Coupe GT Apex AE86 | THA STI GUY | Cars for Sale/Trade | 6 | 11-10-2014 01:08 AM |
| 1986 AE86 - Imported | stock | Other Vehicles & General Automotive Discussions | 16 | 03-02-2014 11:51 PM |
| My Levin AE86!!! | imravenit | Other Vehicles & General Automotive Discussions | 4 | 07-12-2012 09:38 PM |
