Old 10-11-2017, 06:57 PM   #1
Xaftos
The Stripes Add HP
Xaftos's Avatar
Drives: 2017 Toyota 86 860
Disabling launch control in an AT with OFT?
Is this possible by any means?
I feel like I've searched up and down for an answer to my issue (other than "sell it for a manual" or "do a tranny swap") and haven't found one. I've looked in RomRaider for something that pertains to launch control capping me at 2k RPM when both the brake and the accelerator are depressed, and found nothing. Turning track mode on/disabling trac control doesn't do it, nor does the pedal dance I don't think. I'd really like to find out a way to either disable launch control or set it to a higher RPM cap so that I can perform harder launches.
If any of you hold the answer, I'd be very grateful to hear it.
Thanks!
Xaftos is offline   Reply With Quote
Old 10-11-2017, 08:25 PM   #2
steve99
Thanks!
Their is no launch controll setting in oft or ecutek or any other rom\tune for automatics. This is because its a hardware issue it the stall speed of ghe torque converter, if you want it set higher your going to have to change torque converter and possibly other hardware items in the t auto transmission
Old 10-11-2017, 08:42 PM   #3
Xaftos
The Stripes Add HP
Xaftos's Avatar
Fuck that's rough. Thanks anyway man!
Old 10-12-2017, 09:05 PM   #4
Wayno
Wayno's Avatar
Drives: Toyota 86 GTS
You said you searched, but obviously didn't.
You can increase the stall speed if you don't stand on the brake so hard.
As said in every AT launch thread since the beginning of time.
Old 10-13-2017, 08:13 AM   #5
Grady
Grady's Avatar
Just do a neutral drop.
Old 10-15-2017, 02:20 PM   #6
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Launch control on an auto, that’s weird....
Dr. BRZ is offline   Reply With Quote
automatic, control, launch, oft, transmission
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 04:58 AM
Best RPM to set OFT Launch Control to? Aztec Software Tuning 12 03-23-2015 08:56 PM
Cruise control disabling JamesBond000 Electronics | Audio | NAV | Infotainment 7 07-02-2014 08:57 PM
traction control disabling through software? puma Software Tuning 16 04-26-2014 10:48 AM
Disabling Traction Control (TC) and Vehicle Stability Control (VSC) Completely BabyGodzillaGTi-R BRZ First-Gen (2012+) — General Topics 40 04-25-2012 11:20 AM
