Old 10-01-2017, 10:14 PM   #1
XanRules
A Very Powerful Wizard
XanRules's Avatar
Drives: 2014 BRZ LTD WRB (RIP), 2017 FiST
BRZ Head Unit Issues since iOS 11
Anyone else run into this? My phone has been acting up since the most recent update. It just keeps acting like I’m plugging and unplugging it, which is a problem since I stream music via USB. It’s not a problem with cables or the charging port since this doesn’t happen if I use a car charger and I’ve now tried this with four cables to replicate the problem.
Anyone else?
XanRules is offline   Reply With Quote
Old 10-03-2017, 02:47 PM   #2
XanRules
XanRules's Avatar
if anyone else has this problem: turning "Do Not Disturb while driving" from "When connected to Bluetooth" to "Manual" seems to have fixed it.
The Following User Says Thank You to XanRules For This Useful Post:
winstonscifi (10-03-2017)
Old 10-03-2017, 02:52 PM   #3
TofuJoe
Ohne Titel
TofuJoe's Avatar
Drives: 2017 BRZ PP ISM
I've been fine on iOS 11 with an iPhone 6 Plus in a 2017 BRZ.
Good info on the "Do not disturb while driving" setting. Thanks! I had that shizz turned off.
TofuJoe is offline   Reply With Quote
Old 10-03-2017, 03:15 PM   #4
DandoX
Senior gif poster
DandoX's Avatar
Drives: 2013 Asphalt FRS
Anyone else?
I haven't updated (which at this point you should only do at your own risk). But I have some suggestions how to hopefully fix it.
First see if it is your connection by connecting to your computer. The ability to charge doesn't use all the connections that are used to transmit data so by connecting to a computer and syncing and backing up should rule out your phone connection.
If this doesn't reveal any issues then you should try streaming music via audio out headphone jack and make sure that works. If that isn't an ideal solution you can look into using Bluetooth to wirelessly connect to your HU
If all else fails you will need to perform a full back up of your phone and make sure everything is saved then do a full restore, issues like this can be caused by an error in the update process. If the issue continues to persist then it is likely due to the latest version of IOS 11, in which case you can just update as soon as the next one comes along to hopefully fix your issue. You can also try and log a ticket with Apple so they know IOS 11 may be causing these sort of issues and they can investigate and hopefully get a fix in the next update.
Hope that helps.
DandoX is offline   Reply With Quote
Old 12-16-2017, 08:41 AM   #5
redfred
Drives: Red BRZ
Thanks, Im having the same issues, '13 head unit. Until recently I had no issues connecting my iPhone 6.
redfred is offline   Reply With Quote
Old 12-17-2017, 09:24 AM   #6
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
I am also having issues, it messes up the pandora app really bad.
-B
HeresMyMind is offline   Reply With Quote
Old 12-18-2017, 05:13 PM   #7
redfred
Drives: Red BRZ
Thanks, mine worked this morning using an AUX cable and charging through the lighter. Not ideal, hopefully someone here has an solution.
Old 12-18-2017, 07:09 PM   #8
Madenn86
Drives: Blue 2013 Subaru BRZ limited
My headunit is on but none of the controls light up and they arent functioning any ideas?
Madenn86 is offline   Reply With Quote
Old 12-19-2017, 10:13 AM   #9
ncted
Drives: 2017 BRZ Limited
My '17 HU has never been particularly usable with my iPhone plugged in via USB. I use BT. Early releases of iOS 11 caused me BT issues at first, but things seem to have stabilized.
ncted is offline   Reply With Quote
For Sale: Stock BeSpoke Premium Audio head unit with NAV unit Glok24 Audio/Visual, Electronics, Infotainment, NAV 13 07-22-2018 12:34 AM
WTB FRS Head Unit Pinkbulate Canada Classifieds 3 03-31-2018 05:20 PM
Audio Issues With Android Head Unit Skippman Electronics | Audio | NAV | Infotainment 1 11-17-2015 09:52 PM
Head Unit Issues GotBRZ1691 Issues | Warranty | Recalls / TSB 8 04-30-2015 10:38 AM
BRZ Sport Tech Head Unit issues? Skurj CANADA 3 04-04-2013 08:40 PM
