Drives: Satin White Pearl
OFT Launch Control. Removed Clutch Return Spring.
Hey guys, I have the Stage 2 UEL e85 tune on my car with OFT and I understand that the OTS tunes come with launch control set at 5.6k. Over the weekend, I removed the clutch pedal return spring and I noticed that when I try to redline it triggers the launch control, even though I don't have the clutch pressed. Is this normal or should I be concerned?
#2 | |
It wont be triggering the launch rpm limit it will be triggering the flat foor shift limiter Oft launch works pirly off vehicle speed speed belpw threshold ie 8 kmh rpm limited to lainch limit, doesnt care about clutch switch. FFS limit is triggered pirly off thte clitch switch at top of clitch travel if clifch switch triggered then rpm limited to ffs limit. Id say your clitch switch is fauly or needs adjistment. The gear display will go out if clutch switch is triggered |
#3 | |
Edit. I also have no trouble hitting redline when I'm driving. |
#5 | |
Drives: 2013 FR-S, 2015 TC
The launch control is only turned on/off by vehicle speed, the default is 6mph I think. If you are wanting to disable the LC you can just set the rpm delta to 0 and the vehicle speed to 0 in Romraider. This will effectively tell lc to only activate at 7500rpm and if you are going 'slower' than 0 effectively disabling LC. Otherwise, this seems to be normal operation, the LC is not determined by clutch position at all. afaik Flat foot shifting is disabled by default with the ots oft tunes.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY KANSAI DORIFTO |
#6 | |
#7 | |
Correct if you set lc to say 5000 (delta 2500) then the car will never rev over 5000 when stationary regardless of clutch position, lc works purly off vehicle speed under 8 then rpm limited over 8 speed then full rpm |
#8 | |
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily 2013 BRZ limited - new toy |
| Tags |
| clutch, control, launch, oft, spring |
| Clutch return spring removal | MikeyBRZ | Engine, Exhaust, Transmission | 186 | 09-16-2020 12:40 PM |
| Help on Launch control disable speed to control wheel spin during launching | j.boy | Software Tuning | 8 | 02-01-2016 04:58 AM |
| FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped | susko | Transmission and Driveline | 2 | 01-21-2016 03:42 AM |
| Next-gen Infiniti G-series to launch Spring 2013 - report | quik1987 | Other Vehicles & General Automotive Discussions | 8 | 01-14-2016 06:35 PM |
| Looking for BRZ in NoVA area w/ helper spring removed! | Synkronicity | Mid-Atlantic | 0 | 05-28-2015 12:36 PM |
