Old 09-27-2017, 02:00 AM   #1
IvanPwns
Drives: Satin White Pearl
OFT Launch Control. Removed Clutch Return Spring.
Hey guys, I have the Stage 2 UEL e85 tune on my car with OFT and I understand that the OTS tunes come with launch control set at 5.6k. Over the weekend, I removed the clutch pedal return spring and I noticed that when I try to redline it triggers the launch control, even though I don't have the clutch pressed. Is this normal or should I be concerned?
IvanPwns is offline   Reply With Quote
Old 09-27-2017, 03:08 AM   #2
steve99
Drives: FT86
It wont be triggering the launch rpm limit it will be triggering the flat foor shift limiter
Oft launch works pirly off vehicle speed speed belpw threshold ie 8 kmh rpm limited to lainch limit, doesnt care about clutch switch.
FFS limit is triggered pirly off thte clitch switch at top of clitch travel if clifch switch triggered then rpm limited to ffs limit. Id say your clitch switch is fauly or needs adjistment. The gear display will go out if clutch switch is triggered
Old 09-27-2017, 03:22 AM   #3
IvanPwns
Sorry, I should have mentioned that when I tried to redline I was stationary. Do the OTS tunes come with FFS?
Edit. I also have no trouble hitting redline when I'm driving.
Old 09-27-2017, 06:16 AM   #4
steve99
Drives: FT86
Yrs they have both, set both delta rpm to zero and see if problem solved
Old 09-27-2017, 10:42 AM   #5
Takumidesh
Takumidesh's Avatar
Drives: 2013 FR-S, 2015 TC
I am a little confused, you said that you are hitting the redline, while stationary but without the clutch pushed, so do you mean that you are in neutral?
The launch control is only turned on/off by vehicle speed, the default is 6mph I think.
If you are wanting to disable the LC you can just set the rpm delta to 0 and the vehicle speed to 0 in Romraider. This will effectively tell lc to only activate at 7500rpm and if you are going 'slower' than 0 effectively disabling LC.
Otherwise, this seems to be normal operation, the LC is not determined by clutch position at all.
afaik Flat foot shifting is disabled by default with the ots oft tunes.
2013 FR-S Basically Disassembled in the garage.
2015 TC BONE STOCK BABY
KANSAI DORIFTO
Takumidesh is offline   Reply With Quote
Old 09-27-2017, 02:37 PM   #6
IvanPwns
No, the only time I don't red line is when I'm stationary without the clutch pedal pressed. I can hit red line when I'm going. So this is to be expected with LC?
Old 09-27-2017, 05:38 PM   #7
steve99
Drives: FT86
Correct if you set lc to say 5000 (delta 2500) then the car will never rev over 5000 when stationary regardless of clutch position, lc works purly off vehicle speed under 8 then rpm limited over 8 speed then full rpm
Old 09-27-2017, 08:34 PM   #8
nocoolname
That's what launch control pretty much is, a lower rev limit from a stop as to limit power to the wheels instead of feathering the clutch as much during launch. Sounds like it's working normal to me.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
clutch, control, launch, oft, spring
Clutch return spring removal MikeyBRZ Engine, Exhaust, Transmission 186 09-16-2020 12:40 PM
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 04:58 AM
FS: MTEC Shifter Spring Kit + Clutch Spring Kit BRAND NEW $59 shipped susko Transmission and Driveline 2 01-21-2016 03:42 AM
Next-gen Infiniti G-series to launch Spring 2013 - report quik1987 Other Vehicles & General Automotive Discussions 8 01-14-2016 06:35 PM
Looking for BRZ in NoVA area w/ helper spring removed! Synkronicity Mid-Atlantic 0 05-28-2015 12:36 PM
