Old 09-24-2017, 11:02 PM   #1
Dailydrifter
Drives: 13' Asphalt grey FRS
Methanol power!
So ive been playing with the tuning on my car lately i had intake, catless front pipe, muffler delete, and i mixed 10 gallons of 91 pump gas with a gallon of 99.9% pure methanol, also added a touch of fuel stabilizer to prevent the fuel from separating. I tuned my car with the OFT ots tunes, stage 2 93 oct for EL header and WOW. It pulls so much stronger through the entire rev range. I pulled with a civic SI kseries 2.4 before i ran mixed gas and and had it tuned and he pulled like 3-4 car lengths from 60-140. Just did a fee pulls with the same car and i pulled 2-3 lengths on him from 60-140. Very happy with the results of my tune. When i dont run meth in the gas i flash back to 91 stage 2 tune and it runs great, i assume my catless front pipe muffler delete and intake are enough to make up for a header considering it can be ran on an entirly stock car besides the header.
Dailydrifter is offline   Reply With Quote
Old 09-24-2017, 11:30 PM   #2
Turdinator
Señor Member
Turdinator's Avatar
I hope you kept an eye on your AFRs. Do you have E85 available near you?
1974 TA22 Celica
2013 86 GT
Old 09-25-2017, 08:48 AM   #3
Dailydrifter
Closest e85 to me is a few provinces away, im on an island in atlantic canada :/
Old 09-25-2017, 08:49 AM   #4
Dailydrifter
I took a data log of a 3rd gear pull through 2k-redline and afrs were on point
Old 09-25-2017, 11:50 AM   #5
bfrank1972
Drives: 2013 FR-S Argento
Woof, to me sounds a little risky - methanol is quite a bit more corrosive than E85, and I hope that stabilizer does the job of keeping things from separating. Keep an eye on your AFRs as your tank gets low
bfrank1972 is offline   Reply With Quote
Old 09-25-2017, 02:43 PM   #6
Dailydrifter
I mixed up a cup of it and left it undisturbed for 2 days no sign of separation, also i always give the steering wheels a few flicks when i start driving to mix the gas in the tank around. Definitely not a long term solution where methanol is corrosive but i think ill be fine if i hust flash to 93 every now and then when i decide i want a little extra out of it. Dont want to be mixing gas all the time. Its only 10% mixture so shouldnt be a problem.
Old 09-25-2017, 03:32 PM   #7
Detroiter
Detroiter's Avatar
Drives: 2014 Scion FR-S Monogram
I would be very careful with this. You are running a tune designed for 93 and a aftermarket catless header. I would constantly run with the OFT plugged in monitoring AFR(like others have said) but also IAM, knock correction, and FLKC. Another danger of running a mixture like this is that Methanol requires more fuel to reach the same AFR than standard gasoline. The more methanol you put in the more fuel you have to tune the car to add.
Raven
OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap
Detroiter is offline   Reply With Quote
Old 10-14-2017, 07:22 PM   #8
-Willis-86touge
Drives: Stock
So quick question did you tune it your self or just running the oft 93 tune.
-Willis-86touge is offline   Reply With Quote
Water/methanol or flex fuel Dinko Forced Induction 28 12-17-2017 10:43 PM
Methanol in NoVA agill Mid-Atlantic 1 09-01-2017 09:54 AM
Water Methanol Injection? NA application. hmong337 Engine, Exhaust, Transmission 12 07-16-2014 01:19 PM
water methanol injection Silverdub Forced Induction 22 07-11-2013 04:58 PM
AEM WATER METH METHANOL INJECTION KIT JPxM0Dz Engine, Exhaust, Transmission 10 04-14-2013 12:03 AM
