Old 09-23-2017, 11:35 PM   #1
JamesK
Drives: 2013 - Toyota 86
Drivetrain, axels, diff
Would it be a bad idea to upgrade the drive train, axels and diff around 2-4 weeks before throwing in the built engine and turbo kit? As in would it be harmful to the car as I'll be daily driving it for around a month before completed?
JamesK is offline   Reply With Quote
Old 09-24-2017, 02:04 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I mean, if you are going to have the transmission and engine out anyway, you are better off just doing it then. I don't see any way a tougher drive train can cause you problems. Maybe slightly slower due to increased losses, but I doubt you would even notice.
Edit, assumed tranny was coming out too. If that's not the case, then ignore my first sentence.
Old 09-24-2017, 02:08 AM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
That sounds like a good idea actually?....cuz you get to break in the trans first?
But I guess you can do it at the same time too since it should be cheaper to do it all at once?
Old 09-24-2017, 03:43 AM   #4
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
That's exactly what I did, you can see my build page. I did the driveshaft first, then trans and diff with axles. Then put in a built motor and turbo kit. It will not harm or cause any ill effects.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
JamesK (09-24-2017)
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
WTB: SOCAL: rear axels :) mr. slim Want-To-Buy Requests 0 11-04-2014 12:25 AM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
