Old 09-23-2017, 11:35 PM   #1
JamesK
Drives: 2013 - Toyota 86
Drivetrain, axels, diff
Would it be a bad idea to upgrade the drive train, axels and diff around 2-4 weeks before throwing in the built engine and turbo kit? As in would it be harmful to the car as I'll be daily driving it for around a month before completed?
JamesK is offline   Reply With Quote
Old 09-24-2017, 02:04 AM   #2
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
I mean, if you are going to have the transmission and engine out anyway, you are better off just doing it then. I don't see any way a tougher drive train can cause you problems. Maybe slightly slower due to increased losses, but I doubt you would even notice.
Edit, assumed tranny was coming out too. If that's not the case, then ignore my first sentence.
Spuds is online now   Reply With Quote
Old 09-24-2017, 02:08 AM   #3
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
That sounds like a good idea actually?....cuz you get to break in the trans first?
But I guess you can do it at the same time too since it should be cheaper to do it all at once?
Old 09-24-2017, 03:43 AM   #4
Drakiv
Project Shadow
Drakiv's Avatar
Drives: 2015 BRZ Limited 6MT
That's exactly what I did, you can see my build page. I did the driveshaft first, then trans and diff with axles. Then put in a built motor and turbo kit. It will not harm or cause any ill effects.
FBM Stage 2 Turbo Project Shadow Build
614whp/421tq on E85
Instagram: Drakiv
Drakiv is offline   Reply With Quote
The Following User Says Thank You to Drakiv For This Useful Post:
JamesK (09-24-2017)
Which is better? Reaplcing rear diff bushings? or installing rear diff brace? Frs30 Engine, Exhaust, Transmission 22 04-13-2020 10:23 AM
Diff Mount Inserts install - Diff won't lower??? ChRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 07-17-2017 12:07 AM
Swap AT Diff with MT Diff sydious Engine, Exhaust, Transmission 2 03-17-2016 02:59 PM
WTB: SOCAL: rear axels :) mr. slim Want-To-Buy Requests 0 11-04-2014 12:25 AM
Drivetrain experts! Name this car! :) aspera Engine, Exhaust, Transmission 200 08-15-2010 11:41 PM
