Old 09-16-2017, 12:06 PM   #1
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
Sebring, BRZ & Tarmac II's
So I'm attending my first HPDE in a twin and was wondering if anyone had any setup recommendations for one running RCE Tarmac II's. (Bump & Rebound).
All my previous HPDE's were in a 3,600lb AWD understeering pig (in the background of the pic below) so the transition to a RWD over-steering BRZ should lead to a fun weekend.
Opie is offline   Reply With Quote
Old 09-16-2017, 11:29 PM   #2
FirstWinter
Drives: Car
The settings in the manual are a good starting point. Tune to preference/track from there. Since Sebring is a bit bumpy you might want to bump back compression/rebound a couple clicks. Of course the rest of your setup will also determine how your dampers are set.
FirstWinter is offline   Reply With Quote
The Following User Says Thank You to FirstWinter For This Useful Post:
Opie (09-17-2017)
Old 09-17-2017, 09:40 PM   #3
Jamestl
Drives: None
Opie... do you work at a subie dealer?
I bought your LGT if you are who I think you are...
Jamestl is offline   Reply With Quote
Old 09-20-2017, 11:19 AM   #4
Opie
Opie's Avatar
I do, I sold my ABP LGT to a guy from New York in 2010...was wondering if it would ever surface again. Still in good shape?
Old 09-20-2017, 02:28 PM   #5
Racecomp Engineering
I's start here and add bump in 2 click increments. I would NOT rely on rebound to calm the car thru turns 17 and 1. Seems like backwards thinking but it works.
Front rebound 10 clicks ( from full stiff)
Front bump 12 clicks
Rear rebound 13 clicks
Rear bump 8 clicks.
Randy Pobst ran the Chin Motorsports car there and loved it. That car DID have 500 lb springs on it and ran close settings to this but with 3 clicks MORE bump damping.
Myles
The Following 3 Users Say Thank You to Racecomp Engineering For This Useful Post:
FirstWinter (09-20-2017), Opie (09-20-2017), smg1138 (09-20-2017)
Old 09-20-2017, 04:16 PM   #6
Opie
Opie's Avatar
Thanks Myles! I actually had the Chin car at my house for a few months (I fixed a tranny issue for them that came up at the May Sebring event) and loved it, I am building my BRZ using a lot of info I learned from the Chin car.
My BRZ is currently set as you listed above, alignment & corner balancing was done today. Ready to go get some seat time in a week and a half.
The Following User Says Thank You to Opie For This Useful Post:
Racecomp Engineering (09-20-2017)
Old 09-20-2017, 04:18 PM   #7
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Rear bump 8 clicks.
Myles
Thanks for that info, Myles. Do you remember the ride height and camber settings when Randy drove that Chin Motorsports car?
smg1138 is offline   Reply With Quote
Old 09-20-2017, 04:23 PM   #8
Jamestl
Drives: None
A guy from New York is me Moved to Chicago about two years ago.
I sold the car about two years after I bought it from you. Added a DP and TMIC and a tune for a little more power, but left it pretty much as is otherwise. It was very tastefully modified so I didn't need to do anything.
Looks like we both wanted to move to something lighter and more fun! I got my FRS a few months ago and have taken it to a couple of track events. A ton of fun so far.
Good to reconnect again!
The Following User Says Thank You to Jamestl For This Useful Post:
Opie (09-21-2017)
Old 09-21-2017, 12:43 PM   #9
They're posted somewhere in the suspension forum, but I'd have to dig for them. They're surprisingly not that aggressive.
- Andrew
The Following 2 Users Say Thank You to Racecomp Engineering For This Useful Post:
jmark (09-21-2017), smg1138 (09-21-2017)
Old 09-21-2017, 01:18 PM   #10
FirstWinter
Drives: Car
- Andrew
Found the set up that Randy drove. From the earlier pages in the thread the spring rates seem to be 560 lb/in (10k) - they are running NT01s.
I've been thinking about going from 400/400 on my T2s to something stiffer like 504/616 (9k/11k). You have any experience with that set up on the T2s? I'm looking for a little bit more rotation and it still isn't quite there with the Perrin RSB I have on now. I might play with the damper settings this weekend though to see if I can get it just where I want it.
jmark (09-21-2017)
Old 09-21-2017, 01:44 PM   #11
I believe he was on the standard 400/400 rates, and added the stiffer springs later.
- Andrew
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
Old 09-21-2017, 02:40 PM   #12
renfield90
The Stig's German cousin
500/600 is my current T2 setup (autocross application FYI). It does rotate better than my old 400/500 setup, to the point that I actually took some rear bar out. Definitely worth a shot.
The Following 2 Users Say Thank You to renfield90 For This Useful Post:
FirstWinter (09-21-2017), Racecomp Engineering (09-21-2017)
Old 09-21-2017, 02:46 PM   #13
FirstWinter
Drives: Car
I use the car primarily on the track. Don't do as much autox anymore. I was looking at starting with 500 lb in the rear and tuning from there with the rear swaybar. I'll definitely give it a try first before going higher.
Old 09-21-2017, 03:15 PM   #14
Pat
Pat's Avatar
Drives: 2023 BRZ
- Andrew
Man, that just seems like a setup that would understeer much more than I would want and certainly more than my car does. Even with 1* more camber in the front than the rear and no toe my car on T2s with standard springs and suggested settings understeered more that I like.
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now Racecomp Engineering Suspension | Chassis | Brakes -- Sponsored by 949 Racing 589 11-21-2021 04:13 PM
***FT-86 SpeedFactory RCE Tarmac 2 Clubsport and Tarmac Zero Sale Thread*** FT-86 SpeedFactory Brakes, Suspension, Chassis 208 09-30-2016 03:43 PM
Sebring Pic gatorac Tracking / Autocross / HPDE / Drifting 1 04-28-2016 07:03 PM
Newbie set-up for Sebring, Help! maj75 Tracking / Autocross / HPDE / Drifting 40 04-16-2013 10:44 AM
Sebring with Dave-ROR LDadrenaline Tracking / Autocross / HPDE / Drifting 9 11-13-2012 10:55 PM
