Old 09-09-2017, 01:34 AM   #1
MassTroy
Subaru BRZ
MassTroy's Avatar
Drives: 2013 Subaru BRZ
Tires turned blue
I took my car to the track 2 weeks ago 6 session of 25 minutes each at Blackhawk Farms over 2 days. I drove the car home and aside from 2 short trips (15-20 minutes) the car has sat since then. Today when I went out to the car I noticed the outer shoulders of all 4 tires seem to be blue. Supposedly this can happen sometimes after high heat in the tires.
Has anyone else seen this with their tires? Does anybody know what exactly causes it? I'm really curious more than concerned.
Tires are RE71R
MassTroy is offline   Reply With Quote
Old 09-09-2017, 01:40 AM   #2
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
This is caused by the scientific fact that RE71Rs are fucking badass tires.
Tires are RE71R
Originally Posted by humfrz
I'm old and lazy
Spuds (09-09-2017)
Old 09-09-2017, 01:44 AM   #3
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
It's common. Just basic heat wear. Power sliding much? Lol
My guess, breaking too late while trying to turn.
Old 09-09-2017, 01:54 AM   #4
MassTroy
Subaru BRZ
MassTroy's Avatar
Can you really narrow down what my driving style is based on the pattern of blue? I certainly wasn't taking it like a drift course, but maybe a tiny bit of angle. The blue pattern seems to be pretty even front to back and left to right (blackhawk is primarily a right hand course but with a long left sweeper at turn 5).
Old 09-09-2017, 02:48 AM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
so much sticky
Old 09-09-2017, 02:53 AM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
TWSS
so much sticky
I'm old and lazy
Ultramaroon (09-09-2017)
Old 09-09-2017, 03:13 AM   #7
Ultramaroon
not playing cards
TWSS
Old 09-09-2017, 03:29 AM   #8
I have never been a track guy but did a pile of drag racing back in the 70s. It is much more impressive when you can manage to get the whole tread (or more accurately, where the tread should be) blue!
Old 09-09-2017, 05:49 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
As I understand it, braking pulls camber out of the rear due to the suspension geometry and when you turn the contact patch moves out to the side more than usual because of the decreased camber angle, thus why the outside edge heats up under those conditions.
Old 09-09-2017, 08:50 PM   #10
wparsons
wparsons's Avatar
Not really... it's the outer edges because of heat from cornering loads.
OP, this is completely normal if you're actually getting heat into the tires. You'll also notice the rubber looks very different between the running surface and the sidewall after a good track day.
flickr
Old 09-12-2017, 02:56 PM   #11
B T
Completely normal. Looks like you may need to increase the air in that tire though, that's a good bit of rollover to the sidewall.
B T is offline   Reply With Quote
Old 09-12-2017, 03:44 PM   #12
brewdad16
Drives: currently shopping
You maybe sliding that tire / that end of the car excessively. That's a lot of heat to change the color. Only time I've seen that on my own cars I was overdriving. YMMV though, if your instructor or data or whatever seems to indicate you're doing fine, that's cool
FRS/BRZ Shopper - for SCCA autox SSC class
prior fun cars: 2010 RX8 R3, 2012 C6Z06, 1994 MR2 track car, 1991 MR2 street car, 1989 Fox Mustang
brewdad16 is offline   Reply With Quote
Old 09-12-2017, 04:52 PM   #13
Icecreamtruk
Drives: Track preped NA FRS
My RS4 tires have this, all 4 of them, almost all of the contact patch has it except for a tiny wit bit in the middle of it (guess I may be running pressures too low after all). My nittos never turned blue tho, so there is certainly some magic to this "street" tires that makes them stick as much as a "slick" tire (nittos and maxxis, which arent really slicks, no more than street tires are at least).
Old 09-12-2017, 08:22 PM   #14
wparsons
wparsons's Avatar
Or more camber... especially if it's a front tire.
flickr
blue, tire, tires, track day
FS/FT OEM Series.blue STI wheels with Winter Tires (SOLD) adamg Wheels and Tires 26 06-11-2015 12:46 PM
Feeler: 18" Gram Lights 57X in winning blue with tires. jadewbj Wheels and Tires 14 02-17-2014 04:56 PM
FS GA: 18x10 +38 Matte Blue Work XD9s with Tires 86TruenoFRS Wheels and Tires 4 11-20-2013 09:03 PM
FS: Gram Light 57X in willing blue 18 inch stagger with tires and centercaps jadewbj Wheels and Tires 19 11-01-2013 08:49 AM
