Drives: none
Newbie question OFT + Invidia Catless Equal Length Steel Header
Hi, I was wondering if the Open Flash Tablet would be compatible with the Invidia Catless Header. I was also wondering weather the Invidia catless header would bolt right onto the Toyota 86 without the need of anything else.
Not a troll
OFT and that header won't work. The header will require a mind boggling amount of custom work to fit properly.
Drives: none
#4 | |
Proud of BOXER
Drives: Subaru Boxer
I suggest a different brand of header if you can afford it. I believe you will be much happier with JDL, Tomei/Gruppe-S, or OFH.
The OFT doesn't care what brand header you use, but be aware that the 17 tunes are not finalized yet, AFAIK.
| The Following User Says Thank You to Clipdat For This Useful Post: | Detroiter (09-09-2017) |
#5 | |
Drives: none
Those are my only choices :/ |
#6 | ||
Proud of BOXER
I see FT86SF catted which is nice, as well as gruppe-s and tomei. Lots of choices there other than the Invidia.
Drives: 2017 manual BRZ
Gruppe S all the way!
Sent from my Pixel XL using Tapatalk |
Drives: none
Ill look at the others, though im going catless. I can't be bothered with catted headers :P (in my Country having a full catless vehicle is 100% legal, as long as the car does not exceed a certain decibel rating)
#9 | |
I don't know which province you are in but all have almost exactly the same wording as the Ontario law. Catalytic Converters (3) If a motor or motor vehicle is manufactured with a catalytic converter, no person shall alter or cause or permit the alteration of the motor or motor vehicle in a manner that permits exhaust emissions to bypass the catalytic converter. O. Reg. 86/99, s.*4. (4) No person shall operate or cause or permit the operation of a motor or motor vehicle that was manufactured with a catalytic converter if the catalytic converter, or any replacement for the catalytic converter, (a) is not capable of performing the function for which the catalytic converter was intended; or (b) is disconnected, removed or otherwise altered so that it is not capable of performing the function for which the catalytic converter was intended. O. Reg. 86/99, s.*4. You can face some heavy fines if caught. https://www.ontario.ca/laws/regulation/980361#BK6
#10 |
Not a troll
| The Following User Says Thank You to Cole For This Useful Post: | StraightOuttaCanadaEh (09-09-2017) |
#11 | |
Drives: none
#12 |
It will probably be buried in an environmental law someplace not necessarily a car one. I wouldn't worry too much about it anyway since I doubt it is enforced by many cops. Just wanted to make sure you knew there was a law not so concerned that you followed it. Ontario has about the strictest and there are many, many, many uncatted cars driving around.
#13 | |
Drives: none
. I don't plan to make my car insanely loud, I just want it loud enough that I can hear a nice exhaust note (If its too loud I may get a exhaust control valve installed). I don't need my neighbors pissed off at me XD. The cops here usually don't stop cars for loud exhaust sounds, unless its insanely loud or neighbors complain.
| WTB Equal / Unequal Length Header | MooKz | Want-To-Buy Requests | 3 | 01-13-2016 06:15 AM |
| WTB Equal Length Header | MooKz | Want-To-Buy Requests | 10 | 12-17-2015 02:15 AM |
| Which headers? Borla Equal Length or FA20club catless? | Norcalmav23 | Engine, Exhaust, Transmission | 5 | 05-25-2013 04:59 PM |
| Borla Releases Equal Length Header, Catless | Huehuecoyotl | Engine, Exhaust, Transmission | 1 | 04-05-2013 09:44 PM |
