Old 08-28-2017, 10:24 PM   #1
samson123
Drives: s2000
bilstein pss coilover?
I've read some specs on the bilstein pss coilovers. I wasn't able to find any info on whether or not it has a preload adjustment separate to to the ride height. any help would be awesome.
thanks
samson123 is offline   Reply With Quote
Old 08-28-2017, 10:56 PM   #2
strat61caster
strat61caster's Avatar
No it does not, the spring perch is your height adjustment.
With the progressive rate spring it should be under pressure unless you go past it's advertised adjustment range, iirc about 35mm lower than stock.
imo after messing with some of those 'separate height and preload' coilovers I much prefer the simpler mechanism.
ineedyourdiddly
The Following 2 Users Say Thank You to strat61caster For This Useful Post:
Racecomp Engineering (08-29-2017), wparsons (08-29-2017)
IN-STOCK Coilover/Suspension Parts Blitz | Tanabe | Apexi | HKS | Bilstein | KW | B&G FRSport.com Brakes, Suspension, Chassis 22 10-19-2017 01:41 PM
WTB: BILSTEIN B14 PSS COILOVER leunggary Want-To-Buy Requests 0 05-19-2016 07:59 PM
Coilover options Bilstein/KW/Öhlins/RCE/Tein brzest Suspension | Chassis | Brakes -- Sponsored by 949 Racing 24 01-03-2016 05:35 AM
Bilstein B14 Coilover vs KW V1 vs KW V3 Stayreal Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 04-18-2014 09:25 PM
>>>Bilstein B16/PSS10 Coilover - US Release<<< FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 69 12-20-2013 12:47 AM
