Drives: 69 Firebird, 2015 BRZ
Whiteline Greaseless swaybar bushings..
Hello Everyone!
Just a little year long end-user feedback on the Whiteline Greaseless swaybar bushings... They hold up very well in the very rough driving conditions of North Central WV... Also the coating on the 20mm 2 position bar that I'm using is still flawless after over 10K miles of use... The only caveat.... The bushings are not greaseless long term... After checking other items first, I was finally force to remove the bar and grease them with proper bearing lube... Smooth and quiet sailing since... :-) Just my 2cents so take it for what it's worth! Ed |
Drives: 2005 Toyota Camry
So basically false advertising?
I'd recommend also wrapping the bar at the bushings with teflon tape.
Drives: Many
One of my whiteline d-link bushings tore in half within a month of install, and I had used a bit of grease on it. After some back and forth white whiteline they sent me a pair of replacements.
I ended up buying a pair of HardRace bushings (16mm) but sold the bar before I got around to install (for sale if anyone wants them). |
| Whiteline spring and swaybar kit | Purist | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 06-11-2017 07:54 PM |
| FS: Whiteline 20mm Front Swaybar | smg1138 | Brakes, Suspension, Chassis | 0 | 04-30-2017 06:28 PM |
| FS: Whiteline Rear sway bar endlinks, New Whiteline rear swaybar mount braces | e1_griego | Brakes, Suspension, Chassis | 1 | 02-15-2017 12:00 PM |
| Aftermarket swaybar bushings | venturaII | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 09-27-2015 07:59 PM |
| replace stock swaybar bushings - any material handing differnce? | brillo | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 11-16-2013 07:15 AM |
