Old 08-25-2017, 08:44 PM   #1
sroby
Drives: 2015 Firestorm 08/05/15
Boost gauge dimmer wiring problem
I am wiring up my boost gauge. It has a black for ground, Red for 12v and yellow for dimmer. I need to know which is the best location to wire the yellow dimmer for the boost gauge light. I have tried the purple wire to the dimmer switch. It doesn't dim. The light stays constant. Can someone help with the local to place the yellow wire so it dims the light. Thx in advance. Steve
sroby is offline   Reply With Quote
Old 08-25-2017, 10:31 PM   #2
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Lots of people installing gauges this week. I tapped my dimmer wire into the "panel" 10amp fuse under the dash.
Cubix is offline   Reply With Quote
Old 08-25-2017, 11:31 PM   #3
sroby
cubix, I remember n some past post I have been reviewing for the last 3 hrs, something about the 10 amp panel fuse. But I'm not understanding completely how the boost gauge light will dim. Is this 12v from the 10amp the analog wire that will operate it? So I will put the red wire from the gauge to the purple wire on the dimmer switch for headlights, and yellow to the 10 amp Panel under the dash. Do I have that correct? Thx partner
Old 08-26-2017, 09:07 PM   #4
Cubix
Cubix's Avatar
Drives: 2015 FR-S
I didn't splice any wires at all. I used those "add a circuit" fuse taps and tapped the following:
- Constant 12v power into the "STOP" fuse
- Switched 12v power into the "DRL" fuse
- Dimmer wire into the "PANEL" fuse
- Ground wire into the bolt
Old 08-26-2017, 09:10 PM   #5
Ultramaroon
not playing cards
Ultramaroon's Avatar
Does the gauge dim along with the speedo backlight?
Old 08-26-2017, 09:14 PM   #6
sroby
cubix I understand now partner. I will get them tomorrow and get it done. The picture and notes explain it perfectly. Thx so much Steve
Old 08-26-2017, 09:22 PM   #7
Cubix
Cubix's Avatar
Drives: 2015 FR-S
Yep. When its night time it dims by about 30% along with the rest of the interior lights and radio.
Old 08-26-2017, 09:41 PM   #8
sroby
Ultra, at this point I am willing to give this a try. I swear this reverse voltage bullshit Subaru crap is crazy. I never once faced any crap like this working on Aerospace ground equipment in the Air Force or on C-130,s or F-15 B models and c models. How freaking difficult should be I just want to wire up a boost gauge so it works and dims when I turn on the lights and want to dim it down at night like my gauges because its to damn bright. What the hell man. Any ideas??
Old 08-26-2017, 09:45 PM   #9
sroby
cubix not to be confusing myself anymore than I already have damn it. I am, clear I believe in your last message, so by dimming like you sad with this method, that dimming will happen via me scrolling the dimmer on the dash or its automatic when the it gets dark?
Old 08-26-2017, 09:58 PM   #10
Ultramaroon
not playing cards
It's not a nitpicky question because I'm not really clear either. I'm almost ready to assume it will dim with the knob because I'm guessing @Cubix means it dims when the running lights are switched on. Right?
Old 08-26-2017, 10:06 PM   #11
sroby
shhheeewww thx partner I swear I thought for a minute I'm losing it. I want to get the gauge 10-8 strait. Then Monday morning I start the open heart surgery of the sprintex. I'm un-marring the oft tomorrow and flashing my ecutek, Delicious 9.5 tune. Then mon I'm=going in deep Ha Ill keep you posted. Best regards my friend. Steve
Old 08-26-2017, 10:20 PM   #12
Cubix
Cubix's Avatar
Drives: 2015 FR-S
It dims when you turn on the lights. With the knob or it set to auto. When the radio dims, the gauge dims.
Old 08-26-2017, 10:24 PM   #13
Ultramaroon
not playing cards
Suh-weet! I've been dragging my feet on the light for my oil pressure gauge. You da man.
Old 08-26-2017, 10:39 PM   #14
sroby
cubix, just dawned on me. My particular gauge only has a 12v red power wire. which this one they suggest goes to 12v switched. I have a yellow wire which is the dimmer wire. then a ground wire. So I will try the 12v switch to the DRL fuse. The yellow to the panel fuse/ then black to ground. I will see what happens. If that doesn't do it, Tell me what gauge you are running and I will mirror your set up if you don't mind. Thx again Steve
Fs: Gauge Pod and Autometer Boost Gauge Juanito08 Interior Parts (Incl. Lighting) 1 06-29-2017 04:36 PM
WTB Instrument Gauge Cluster Dimmer Switch Wire Harness Arcadien Angel Want-To-Buy Requests 1 04-12-2015 09:58 PM
Digital boost gauge w/ vent pod grim speed boost controller Meetjoeblack Engine, Exhaust, Bolt-Ons 0 03-09-2015 01:27 PM
Boost Gauge Wiring trsiidno Electronics | Audio | NAV | Infotainment 0 01-23-2015 06:17 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
