Old 08-20-2017, 05:21 AM   #1
86 South Africa
POWER!!!!!!!!!!!!!!!!!!!!
Drives: White Toyota 86 (Scion FRs)
e85. Some basic questions.
So I wanted to ask some knowledgeable guys a few things;
We know ethanol helps with "cooling", can be used to get more power and has some benefits over normal petrol/gas.
1) if it has a cooling effect then would it naturally help engine longevity? E.g. Same car driven under same conditions for 50,000km on e85 should (all else being equal) last better than a car on normal gas?
Is that a fair comment?
2) apart from higher fuel consumption & possible water issues (if you leave the car standing) what downsides are there to ethanol?
3) if no.1 is true, would it be magnified for FI applications? So under an assumption that added power doesn't damage the engine parts, e85 is better than normal fuel for boosted cars?
I'm not looking for heavily scientific answers... just summarised versions :-)
Cheers,
I like driving!
86 South Africa is offline   Reply With Quote
Old 08-20-2017, 08:05 AM   #2
steve99
E85 has higher octane rating than most petrol especially petrol available at the pump for a reasnoble price . I think in south africa best is 95 ron most e85 will be between 105-107 ron
So its much more knock resistant means you can run more riming na and more timing\boost if your fi without running into knock issues.
The energy content per volume of e85 is about 25% less than petrol so you use about 25% more fuel to produce same power. The extra fuel helps with cylinder cooling again helping with knock and efficiency.
Knock is a big killer of engines so it definitly helps in that area.
But its still the same limits on engine components power torque and load wise no matter what fuel you run. But in general it usually safer to run e85
Modern fiel systems in xars are sealed not open to atmosphere so moisture absorption is not a problem unless you leave your fuel cap off all fhe time.
Ivd stored e85 for months no problem in sealed containers.
3 years pliss on e85 , 50,000 km plus no problems, compldtly stock fuel system
The Following 4 Users Say Thank You to steve99 For This Useful Post:
86 South Africa (08-21-2017), Blue Bird (08-20-2017), Hawk77FT (08-22-2017), Raven86Project (03-02-2022)
Old 08-20-2017, 08:58 AM   #3
Somerandom18
Drives: 2017 manual BRZ
If you have access to e85 there's no reason not to use it.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
The Following User Says Thank You to Somerandom18 For This Useful Post:
Old 08-21-2017, 02:55 PM   #4
86 South Africa
Except fuel consumption
I like driving!
Old 08-21-2017, 03:09 PM   #5
Somerandom18
It's overall cheaper to run than Premium.
Old 08-21-2017, 04:38 PM   #6
Shady195
Drives: '13 10 Series FRS #1203
Not really, it all depends on where you live and the price of e85
Plus factor in oil changes as with E85 they do need to be done more frequently.
I pay more to run E85 in my car than I do if I just ran 93. I get about ~14 average with E85, this is a combination of City/Higway, getting on it here and there, not being "concious" of my MPG just driving the car and having fun.
FYI My car is Turbocharged.
Versus the ~26 average I had when I was 93 only, pretty much driving the car exactly like I do now
E85 where I live is 2.05 a Gallon
93 Where I live is 2.75 a Gallon
It costs ~35 to fill a tank with 93 that previously would get me ~350 Miles to a tank of mixed driving
It costs me ~26 bucks to fill a tank with E85 that gets around 180 miles of mixed driving (if I drive all highway and take it easy, I can stretch about ~260 out of the tank)
I'd need to fill my tank twice to get the same mileage I get from 93, which ends up costing nearly 20 bucks more to get the same distance.
Shady195 is offline   Reply With Quote
Old 08-21-2017, 05:30 PM   #7
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I'm with you. I am JRSC and get about the same mileage as you. When I got the flex fuel kit last year 91 here was about $3.05 and E85 was $1.20. Now 91 is $2.79 and E85 is $2.29!! I don't need to do the math to know running E85 is more expensive.
However, there is a 70HP difference between running 91 and E85. E85 = more fun. I switch between the two depending on what I'm doing.
Old 08-21-2017, 05:44 PM   #8
Somerandom18
That's crazy. My e85 is $1.57 and 93 is $2.89. Sorry.
Old 08-21-2017, 05:59 PM   #9
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
Not to answer OP's questions, but my experience with E85 is great. Over 50k miles, no problems, 1.80 per gallon, and i get about 33mpg. It's not too bad, i have other mods too. Great for power, but on long trips is use 93.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 08-22-2017, 03:54 PM   #10
cjny
Drives: 2016 BRZ
Aren't there some cold start problems?
cjny is offline   Reply With Quote
Old 08-22-2017, 05:40 PM   #11
MurderousPandas
There are, but not too bad. You can mix a gallon of 93 in to help the issue. The car starts but dies, after a couple tries it should work without problems. This is only in cold weather though, not on cold starts.
Old 08-22-2017, 06:48 PM   #12
Shady195
All depends on where you live and the demographic I guess.
I live in upstate new york, the cheapest E85 around me right now is 2.05. The one right by my house is currently 2.78, it costs 2 cents more than 93!
I go down to NYC/Long Island a lot, and I can get E85 down there for about ~1.80 a gallon.
I just deal with the added cost because I no longer drive the car everyday and you can't put a price on smiles.
The Following User Says Thank You to Shady195 For This Useful Post:
Somerandom18 (08-22-2017)
Old 08-27-2017, 11:42 PM   #13
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Ok, filled up again today. E85 at $2.39 now! WTF?
Old 08-28-2017, 10:48 AM   #14
bfrank1972
Drives: 2013 FR-S Argento
Do you live amongst the corn fields?
bfrank1972 is offline   Reply With Quote
e85, ethanol, flexfuel
FS: ISC N1 Basic coilovers- SOLD Agent_D Brakes, Suspension, Chassis 7 08-22-2017 12:24 PM
Basic Mods jarviz Scion FR-S / Toyota 86 GT86 General Forum 16 05-09-2016 03:00 PM
Basic Noob Questions - Camber bolts/alignment/etc Rifle Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 10-28-2015 01:59 PM
BRZ Basic SQ Build hellyvin Electronics | Audio | NAV | Infotainment 13 07-22-2014 12:25 AM
