Old 08-08-2017, 05:07 PM   #1
jc3138
Drives: Ice Silver BRZ 2017 w/PP
Post your subwoofer setup!
I would like to see pictures of your BRZ/FRS/86 subwoofers setups.
Just got my 2017 BRZ looking forward to add some loudness to the audio system under $600 without sacrificing the whole trunk space.
Dealership offered me their $600+ option but i didnt dig it.
jc3138 is offline   Reply With Quote
Old 08-08-2017, 05:20 PM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://lmgtfy.com/?t=i&q=FT86club+subwoofer
I LIKE TIRES!
Old 08-09-2017, 10:51 AM   #3
allowe
allowe's Avatar
Costed less than a 100 bucks. I made a guide on how I did this exact setup a long time ago. It's basically a factory sub box with the sub I got from a junkyard and an amp I had which u can get for like 20 bucks used. It's pretty loud when I want it to be.
allowe is offline   Reply With Quote
Old 08-09-2017, 11:20 AM   #4
Chimera
Drives: FRS
I'm using a JL stealthbox, and an alpine 500/1. admittedly part of what you pay for with JL is the brand name, but I still like the sub. it's not cheap though
Old 08-09-2017, 02:03 PM   #5
Impureclient
Drives: 2015 FR-S
Sub: Infinity Reference 860w 8-Inch 1000w $59 when I bought it in 2015, it's more than double now at $130 though for some reason
Ported Box: Custom made by local shop $50
Amp: Soundstream PN1.450D 450W $99.00 Mounted hidden directly above box(it's very small)
Spent about $208 at the time, currently it would be about $300. It's too loud at 1/4 volume, so it's enough.
Impureclient is offline   Reply With Quote
Old 08-09-2017, 08:56 PM   #6
stevesnj
stevesnj's Avatar
Can I just upgrade the door subs with new subs and an amp for a little more kick? I don't want to lose my fillings listening to Metallica.Recommendations?
My 2016 Build thread
Old 08-09-2017, 08:59 PM   #7
allowe
allowe's Avatar
Upgrading the headunit would make a noticeable difference. You can upgrade the door speaker but you have to pick out a good setup.
The Following User Says Thank You to allowe For This Useful Post:
stevesnj (08-09-2017)
Old 08-10-2017, 01:09 AM   #8
jslack
Drives: 2017 Red subaru BRZ Limited
I'm running a Rockford prime 500x1 Class D amp with a 2 ohm load on a single Alpine type R dual 4 ohm voice coil. in a small sealed box and then running a 2 channel soundstream to the door speakers which is just a set of focal separates. Using the Audio control LC2I for the LOC and a sound stream bass restorer. And in 2 weeks putting in the Kenwood 6903 head unit to get some apple play in the car and the Maestro RR to retain the factory camera and steering wheel controls.
jslack is offline   Reply With Quote
Old 08-13-2017, 10:41 AM   #9
Aznprd21
Drives: 15 frs
2 crunch 12" and kicker cxa1200.1. The prefab box fits with coup space. Okay bass and weight, need to get better subs though for crisper bass.
Aznprd21 is offline   Reply With Quote
Old 08-13-2017, 11:07 AM   #10
allowe
allowe's Avatar
Wtf, how did u fit dual 12inch subs?! Was the box custom?? If not where did u get it
Old 08-13-2017, 03:11 PM   #11
Aznprd21
Drives: 15 frs
Pep boys, jus have to remove foam from trunk
Old 08-14-2017, 01:27 AM   #12
Mim
Mim's Avatar
Drives: MY11 Maxima 350st, MY15 BRZ
Pioneer TS-WX710A amplified Sub. Only weighs 6kg and comes into the boot 9cm. Has 2x 16cm subs, which does not sound like much but its enough to fill out the bass seeing as all the other speakers in the car were updated also including much larger ones in the wall behind the seats.
You can still flip the seat down and use the expanded boot space and its built sturdy enough for you to do so (within reason).
MY15 CWP A/T BRZ | Leather heated seats | STI CAI filter, A/T leather shifter, strut brace, V-brace, draw stiffener, battery tie down, Radiator cap, Oil cap, push start button | TRD door stabilizer | YoSpeed STI console garnish | Pioneer AVIC-F70DAB + Rev-camera, TS-WX710A sub | JL speakers, Amp | TOMS' Clear Brake Lights | Cusco 4.556 FD | Driveshaft Shop aluminum shaft | Tein FlexZ, EDFC AP+GPS | Crawford BPB
Mim is offline   Reply With Quote
Old 08-14-2017, 08:57 AM   #13
Chimera
Drives: FRS
Got a build thread?
Old 08-14-2017, 11:19 AM   #14
Jesse36m3
Jesse36m3's Avatar
Drives: JDL Turbo BRZ
No pictures atm but I'm running:
JL 250/1
Image Dynamics 10" in a small sealed enclosure.
I went for a more modest SQ build this time. I've had my fair share of nearly going deaf in other cars I've owned.
Jesse36m3 is offline   Reply With Quote
The Following User Says Thank You to Jesse36m3 For This Useful Post:
tfp (08-25-2017)
Battery Cutoff switches ? post your setup philooo Tracking / Autocross / HPDE / Drifting 21 06-17-2025 09:51 PM
DashMaker - Post your setup here! 9lives Engine, Exhaust, Transmission 14 11-24-2016 05:12 PM
FS: Entire P&L Stage 1 Turbo Setup - Turn key Setup ready to make 400+whp PrimeMotoring Engine, Exhaust, Bolt-Ons 8 10-30-2015 06:36 AM
Post Your Wheel Setup (Canadian Version) wheelsco CANADA 36 09-27-2015 08:20 PM
Post Pictures of Your Trunk Setup mackdaddytran Electronics | Audio | NAV | Infotainment 10 04-18-2014 10:01 PM
