Old 08-05-2017, 05:52 AM   #1
Gringosteve
Drives: UK Spec GT86
Variable timing live monitor
I am working on a better way of displaying what is going on inside our engine in a Dashcommand skin. It is still early days but wanted to share work so far on a portion of the skin that will display variable timing overlap in real time. Much more to come!
https://www.facebook.com/TunedECU/vi...0405013331208/
I also create custom skins for customers. Message me on Facebook or here for more info.
Gringosteve is offline   Reply With Quote
Old 08-05-2017, 12:12 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
This might help with the cam angles.
The exhaust cam closes before TDC at 0 retard and the same for the intake at 0 advance.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-05-2017, 03:15 PM   #3
Gringosteve
Thanks that should help work out if I have this right! I am measuring cam change angle on odb2 and drawing based on that. I saw a diagram that showed 3 degrees before TDC at closure point, so assumed anything negative was right of TDC.
Do you think I am representing retard wrong?
Old 08-05-2017, 03:25 PM   #4
Gringosteve
Looks right based on this, apart from me measuring 0 as -3! I took the -3 from a different Toyota engine by mistake (google error) will fix it now
Old 08-05-2017, 04:36 PM   #5
Gringosteve
I think I have sorted it. Had the cam angle durations wrong for both sides. Thanks so much for spotting the error!
Old 08-05-2017, 05:55 PM   #6
Kodename47
Kodename47's Avatar
Drives: UK GT86
The problem is that the diagram you posted shows more adjustment range than the cams actually have in the ROM. So I'm not sure if there's a hard or fast value or just to allow tollerances. The values that I got for the spreadsheet are a good indication. I just add cam overlap into my logs now, but even then it's not 100% helpful as its not easy to determine the cam lift.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-05-2017, 06:26 PM   #7
Gringosteve
Yeah I wondered if it was max tolerance.
Once question I have, should I show intake open at TDC or at -3.5 to the right as per this
Old 08-05-2017, 06:54 PM   #8
Kodename47
Kodename47's Avatar
Drives: UK GT86
In that sheet 0 is TDC, negative is BTDC and positive is ATDC.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-05-2017, 07:19 PM   #9
Gringosteve
And so the base cam with no VVT change would be drawn as opening 3.5 degrees left of TDC?
Old 08-06-2017, 03:26 AM   #10
Gringosteve
I guess my question is; when the table shows 0 advance for intake, what angle is the cam at? -3.5?
When the table shows 0 for exhaust what angle is the cam at
From that I can make this diagram accurate.
Old 08-06-2017, 03:42 AM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
At 0 the intake cam opens the valve at 3.5 degrees to the left of TDC and the exhaust valve closes at 7 degrees left of TDC.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-06-2017, 03:44 AM   #12
Gringosteve
Perfect and thanks for all the help will fix this now.
Old 08-06-2017, 04:09 AM   #13
Gringosteve
Ok, think this now matches your sheet at 0 for both intake and exhaust
Old 08-06-2017, 04:16 AM   #14
Gringosteve
One more question, if the intake cam change is given as -10 would the intake be rotating clockwise 10 degrees or anti-clockwise 10 degrees from its 0 point ?
E85 and MPG monitor brillo Software Tuning 12 07-25-2017 10:12 AM
Dealership Accuses Variable Valve Timing (VVT) Ajustment shiro Issues | Warranty | Recalls / TSB 48 12-20-2013 10:03 AM
ANYONE SELLING A GTS MONITOR OR OTHER aymen23q Australia Classifieds 2 01-20-2013 05:54 PM
Re: scion drive monitor revedout Electronics | Audio | NAV | Infotainment 5 12-11-2012 04:55 PM
Rotrak variable supercharger madfast Other Vehicles & General Automotive Discussions 10 01-28-2012 11:14 PM
