Old 08-03-2017, 11:04 PM   #1
shellslinger
Drives: Whiteout FRS
Front Passenger Tire Cupped
Hey guys,
I recently ran into this problem and I'm not sure what is wrong with the suspension or wheel. Only the front passenger side tire is cupped but all the other 3 tires are fine. I took the vehicle over to a local shop to check to see if there was anything wrong with the suspension and they confirmed nothing was wrong with the suspension. They checked the alignment and nothing was wrong.
The only thing that leads me to believe what is wrong is that front tire is unbalanced. However, the cupping is only on the inside of the tire and the car does not vibrate during driving or acceleration.
Do you guys think it could be from worn ball joints? I also don't think my struts are bad either since I just switched them over to RSR Sports I 10k miles ago.
Any help guys?
shellslinger is offline   Reply With Quote
Old 08-04-2017, 11:51 AM   #2
fika84
fika84's Avatar
Tire pressures check out?
fika84 is offline   Reply With Quote
Old 08-12-2017, 09:56 PM   #3
stevesnj
stevesnj's Avatar
Rebalance all tires and check struts for leaks or other damage.
My 2016 Build thread
Old 08-12-2017, 10:52 PM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
The shop was wrong. Cupping is caused by bad dampers. The wheel is oscillating undamped and that causes the cupping.
WTB: Front passenger strut 86kahl Southern California 0 05-03-2016 06:25 PM
WTB front LCA (passenger side) Rinzler_ft86 Want-To-Buy Requests 0 08-02-2015 04:58 AM
WTB Front Passenger Fender WHITEOUT JayeM86 Want-To-Buy Requests 0 09-09-2014 01:36 AM
WTB: Raven front bumper plus front underpanel and passenger side front fender liner THEmailman Want-To-Buy Requests 1 04-20-2014 12:05 AM
WTB: front passenger hub / bearing assembly sw22 Brakes, Suspension, Chassis 1 01-28-2014 12:51 AM
