Drives: FRS
Rear mounts at max height?
If you were running coilovers like V3's or B16's and you set them at their maximum height as per the manufacturers recommendation, would you gain anything by installing rear mounts that increase travel? If the coilovers are already at max height is their any travel to be gained with the top mount?
Drives: 2014 GT86
Rear mounts "that increase travel" simply reposition mountpoint of strut higher. Mostly for cases where one wants to lower car without reducing strut travel for that.
If you already have coilovers set at max height, with those mounts you'll get same "travel" but car will be lowered by amount they state to reposition that mountpoint higher. Think of opposite to lift spacers. Travel same - but car is higher/ground clearance increased with spacers. |
Drives: FRS
Don't they make rear mounts that increase travel but leave the ride height alone? I thought they made mounts that just allow the shock and bump stop to travel a bit higher (into the recess) but the mounting point remains the same..... no?
#4 | ||
You can't add shock travel without changing shocks if they are already fully extended. Max length and min length stay the same. Are you trying to gain travel or height? |
Drives: 2014 GT86
shock/bump stop travel is shock/strut/coilover itself (and it's constructive part, bumpstop) dependent. Different mounts (or spacers to existing ones) don't do anything to reduce or increase travel. Just change mountpoint, allowing with same travel strut be mounted higher or lower. There are also aftermarket LCAs that unlike those mounts change lower mountpoint, but for same purpose. Mostly to allow keep travel while lowering, not actually "increase" it. I guess, product naming must be a bit misleading.
BTW, haven't seen coilovers maximum height being also same as per manufacturer's suggestion (of course, if one leaves unadjustable ones aside). In most cases there is adjustment range, with manufacturer advised setting of somewhere inbetween. Eg. drop 10-30mm with advised 15mm and alike. Though some report that for many coilovers it's possible to adjust also higher then what manufacturer states in specs. And yes, what are your goals, for what are you after? I can only guess from OP if you were considering "setting to max travel", that you want increase that travel/and also maybe increase ground clearance, for something like bad roads compliance/capability? Imho KWs (or based on those RCE tarmac lines) should have more travel then stock suspension. But their overall height/stated adjustment range is less then stock's. So maybe these + lift spacers? There is also TRD rally suspension (+10mm), but haven't seen reviews of it, so not going to advise. Then IIRC there should be something from Feal. Then also uber expensive custom real rally coilovers that most probably will be 3 times outside of your budget and need to be frequently overhauled
Drives: FRS
Just trying to get all the bump travel I can from the rear. I believe the car will be lowered .7" with the KW's at max height which is as low as I want to be. I do appreciate all the input.
Potato Farmer
Drives: #SLOBRZ
It shouldn't change the travel no matter if you have the car at max height or lowered using the same coilover,
different coilovers can have different travel lengths, I think mine are only 100mm, and that was with them being custom made, and with part shop max LCA's which drops the lower mounting of the coilover down. I don't really know much about the KW's though.
Something something butter..
www.vic86brzclub.com |
Drives: 15 BRZ LTD, 05 FXT
I may be in a unique position to help.
I run ST's on all my personal cars, and have been the wrench behind the @LiftedBRZ project. If you're trying run coilovers like the KW's where the bottom mount is fixed, and not what controls ride height, and aren't trying to actually lift it, just run the height at the upper end of KW's recommended ride height. You won't be compromising damper stroke much if at all, that's how KW designed them. If you want to lower your car, while retaining as much stroke as possible, that's where the upper mount options come into play. Something like the Raceseng 1" or 2" upper mount will help you retain 1" or 2" respectively of stroke as you lower past the upper end of KW's recommended ride height. I have my car dropped about 1.3" on ST's with stock top mounts all around, and haven't had any issues with bump stops or lack of stroke. To properly setup these cars with as minimal of a drop as possible, measure hub to fender of your car stock, install and adjust until you have hub to fender - 20mm. That is the correct heighest setting for this coilover kit. These coilovers operating range is a 20-50mm drop. Towards the 50mm end you will experience a lack of stroke, (that's nearly a full 2" drop.)
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
Adding upper mounts that give you more bump travel on the shock do so by giving up droop travel.
If the coilover manufacturer suggests a given drop and you're running higher than that I wouldn't run an upper mount that adds bump travel, you're already getting less droop travel than the manufacturer suggests.
#10 |
I think I'm struggling to understand what OP is trying to achieve, and for what purpose.
| FS: Racer X Rear LCA, Hotchkiss Front Bar, Raceseng 1" Rear Drop Mounts | Kuro86 | Brakes, Suspension, Chassis | 4 | 07-26-2017 03:01 AM |
| WTB: Shorter Height Bump Stops Front & Rear | Brzzee | Want-To-Buy Requests | 0 | 10-27-2016 05:43 AM |
| Rear shock top mounts | rick s | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 08-12-2015 11:32 AM |
| MSI Solid Rear Mounts! | Turn in Concepts | Brakes, Suspension, Chassis | 1 | 02-06-2014 12:22 PM |
| Koni Rear Ride Height Too High; Install Issue | rene0023 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-06-2014 05:01 PM |
