Old 07-27-2017, 02:22 PM   #1
brillo
Drives: 2013 Firestorm FR-S
rubber bushing life question
So my car has more years (4) than miles on it (15k). I'm trying to understand the average life of the various rubber bushings assuming 1-3 HPDE events a year that is not a daily driver.
At what point will the steering rack, differential and various control arm bushings start to fail? Mileage is not likely going to be an issue on the car at the rate I'm going and I plan to keep the car indefinitely.
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-27-2017, 02:52 PM   #2
swarb
The Following User Says Thank You to swarb For This Useful Post:
strat61caster (07-27-2017)
Old 07-27-2017, 03:12 PM   #3
strat61caster
strat61caster's Avatar
Based on your mods I'd be surprised if your bushings went any quicker than a standard street car, imo track pavement is much smoother and kinder than average street pavement, cornering loads aren't the killer, it'll be the constant deflection and movement of rolling around bumpy pavement that puts more wear into rubber joints imho.
I'm at 60k miles so far, 5x track days, bit of autox, the bushings in my car appear to be perfectly fine and I'll be disappointed if there is more than an oddball failure or two before I hit 10yr/10k miles.
I bet they use the same rubber in this car that they do in any Corolla or Impreza, designed to take a decade+ of commuting and negligence before they run out of life.
ineedyourdiddly
Tcoat (07-27-2017)
Old 07-27-2017, 04:24 PM   #4
A lot of concern over the life span of bushings goes back several decades when they still actually use rubber. Up until the mid 80s or so most bushings would start to fall apart after as little as 5 years. Modern bushings have no natural compounds in them and time will have little impact. Beyond simple wear the only real enemies for modern bushings are extreme heat, extreme cold and UV exposure. If left sitting long enough the car could probably rust away and the bushing would still all be good.
Whiteline KDT922 (Subframe Bushing Inserts) Grease - Safe to use on Rubber? eckoflyte Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 07-14-2018 11:24 AM
Trailing Arm Bushing Question? TRAKRAVN Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 01-04-2016 09:43 PM
Suspension Arm Bushing Replacement Question brillo Tracking / Autocross / HPDE / Drifting 0 05-09-2015 08:40 AM
Rubber bushing LCAs unsurety Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 06-15-2014 03:19 PM
Garage Life: We bring your dreams to life! Garage Life Southern California 0 08-17-2012 07:33 PM
