Old 07-22-2017, 12:34 PM   #1
etherdude
Drives: 2020 Hakone Edition, 2015 FR-S
TRD Exhaust - 2 Questions
Hello all,
After 32,000 miles, I took the TRD "D tip" Exhaust off of my 2015 FR-S, cleaned it up and put it in storage along with all new gaskets and bolts for reinstallation. I put the stock exhaust back on because of the noise on long trips. While I really like the sound of the TRD exhaust for around town driving, and it is a quality piece in near perfect condition, it made listening to the audio system on long (400+ mile) solo trips just too much and I would arrive fatigued.
My questions are two:
  1. Is there any difference in the 2017 86 that would preclude installing this part from my 2015 FR-S? The TRD catalog seems to indicate that it should be backwards and forwards compatible from 2013MY to 2017MY. I seem to recall that someone on the forum had a problem installing an aftermarket exhaust component system from an older FR-S to a new 86. (I know the headers are different!). [NEVER MIND, I answered this question by searching! the issue was axle backs where the hole spacing is a bit different at the rear end of the tailpipe flange. Not at the mid-pipe/tail-pipe spring bolt flange]
  2. The front end of the tailpipe and resonator on the TRD are smaller diameter than the mid-pipe and then open up after the resonator to the same diameter as the stock tailpipe and resonator. Has anyone considered splicing the stock tailpipe and resonator into a TRD tailpipe? I would think the sound would quiet down a bit (larger resonator) and be a bit deeper (larger diameter pipe). If so, this might meet my desire for sporty, but less intrusive highway cruising.
etherdude is offline   Reply With Quote
Old 07-22-2017, 01:48 PM   #2
humfrz
Well, I hear that about aftermarket mufflers being a bit "much" for long haul trips. I've often thought about switching out for trips ..... just thought about it.
A "quick disconnect" coupler and hangars would be a handy feature for aftermarket mufflers ...... remember, you heard about it here first .....
humfrz
exhaust questions StraightOuttaCanadaEh Engine, Exhaust, Transmission 4 04-20-2017 12:10 PM
New 86 Exhaust Questions KennethJohnson Engine, Exhaust, Transmission 12 02-03-2017 11:46 PM
Exhaust Set-Up Questions Anderzz Engine, Exhaust, Transmission 5 08-26-2016 04:17 PM
Exhaust Questions! Bjeoen Engine, Exhaust, Transmission 3 12-02-2015 01:21 AM
Exhaust Questions? 636 Engine, Exhaust, Transmission 6 10-19-2013 05:14 PM
