Old 02-03-2017, 08:50 PM   #1
KennethJohnson
Drives: 17' 86 16' GSXR-600 Bike life
New 86 Exhaust Questions
I might pick up an 86 and I have a few questions...
First of all, can I do the sound tube delete without any repercussions?
(I'll be looking at that more in the next few days)
Also, if I get a cat delete will I have to get my car tuned so it won't throw codes?
Will shops do that legally in CA?
Don't have to smog a new car for the first 6 years of ownership here =]
KennethJohnson is offline   Reply With Quote
Old 02-03-2017, 08:58 PM   #2
Cole
Not a troll
Cole's Avatar
You can delete the sound tube no problem for about 2 bucks and 10 minutes of work.
The cat, I wouldn't risk myself in Nazifornia. But, yes, you should do a tune when you install a catless header.
Old 02-03-2017, 08:59 PM   #3
gramicci101
Off Topic
Yes.
Yes.
No.
Doesn't matter. I think it's a federal offense to tamper with a correctly-functioning emissions system. Shops would be risking tremendous fines if they did that for you.
Old 02-03-2017, 09:00 PM   #4
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
1.) Yes
2.) No, no tune required if you're just removing the secondary cat in the front pipe with a catless FP.
3.) I suggest DIY, it's super easy!
Originally Posted by humfrz
I'm old and lazy
Old 02-03-2017, 09:15 PM   #5
KennethJohnson
1.) Yes
Oh fuck there's two cats? Derp more research time :P
But what about the O2 sensors tho? Won't they throw codes?
I'm assuming if there's 2 cats there is probably 4 O2s?
Old 02-03-2017, 09:16 PM   #6
Cole
Not a troll
Cole's Avatar
No. There's only two, in front of and behind the primary cat which is on the exhaust manifold.
The Following User Says Thank You to Cole For This Useful Post:
KennethJohnson (02-03-2017)
Old 02-03-2017, 09:18 PM   #7
k_mono_FRS
k_mono_FRS's Avatar
Drives: 94 EG6 si, 97 DelSol si, 14 Monogra
I drove my FRS on the wild side in SoCal. Tomei EL header, overpipe, Ti front pipe, and 60r exhaust. Best part is its lighter than half the weight of the factory setup and other drivers notice you in their blind spots. Loud and obnoxious but I'll have it no other way lol.
I don't know many shops that will delete your cats. If your willing to get your hands dirty and have a set of metric tools... you can do it by yourself in your garage.
k_mono_FRS is offline   Reply With Quote
Old 02-03-2017, 09:21 PM   #8
KennethJohnson
Is this a bolt-on job? If so EZ PZ
I can't weld though.
Old 02-03-2017, 09:25 PM   #9
k_mono_FRS
k_mono_FRS's Avatar
Most aftermarket exhaust systems are plug and play... so yes bolt on. No welding required unless you buy a cheapo universal setup.
The Following User Says Thank You to k_mono_FRS For This Useful Post:
Old 02-03-2017, 09:57 PM   #10
KennethJohnson
can i run those downstream pipes without the header and still be good without a tune? no blowback? pops are fine i just dont want my engine to flex O.O
Old 02-03-2017, 10:23 PM   #11
humfrz
As far as the sound tube, it's easier just to "stick a cork" in the outlet, which comes through the firewall in the right side footwell.
humfrz
Cole (02-03-2017)
Old 02-03-2017, 10:26 PM   #12
Cole
Not a troll
Cole's Avatar
humfrz
Yes but you you still have the sound tube in the engine bay.
It took me a 15 minute trip to the hardware store to get a plug and a clamp, and then 10 minutes to open a beer, and do the job. Worth it if the mod bug is biting.
Old 02-03-2017, 10:46 PM   #13
humfrz
Well, yes, but with my method ...... one could have had 3 beers .....
humfrz
Cole (02-03-2017)
Exhaust Set-Up Questions Anderzz Engine, Exhaust, Transmission 5 08-26-2016 03:17 PM
Exhaust Questions! Bjeoen Engine, Exhaust, Transmission 3 12-02-2015 12:21 AM
J2 Quad Exhaust Questions HachiRo Cosmetic Modification (Interior/Exterior/Lighting) 4 01-23-2015 07:55 AM
Exhaust Upgrade questions Lord Peth Engine, Exhaust, Transmission 11 07-24-2014 10:32 AM
Exhaust Questions? 636 Engine, Exhaust, Transmission 6 10-19-2013 04:14 PM
