Drives: 2013 Subaru BRZ
Best gas pedal
Heel and toe is annoying in the brz it's doable but takes too much foot gymnastics I'm looking for a pedal to mostly raise the location and move it over to the left a bit
Drives: 2015 Ultramarine Scion FR-S
There seem to be quite a few here that might do what you are looking for. http://www.ft86speedfactory.com/cata...?cat=0&q=Pedal
Sent from my ONE E1005 using Tapatalk |
The Dictater
Drives: '13 Red Scion FRS
Brake harder?
not playing cards
haha....
![]() Depends on the size of the feet. I had the opposite problem driving a friend's who had the cusco kit.
Drives: 2014 GT86
From my experience best bet would be those pedal assembly spacers, that not just relocate closer to brake pedal, but also rise it.
There is one caveat to those - spacers work well with stock pedal, but if combined with aftermarket ones that are longer and wider to left, then combo gets too close to brake pedal, and it's easy to misspress. Both ease heal & toe, but preferred spacer route. At some point had also Neoplot pedal, but after trying out all combos, left spacer (PST) + stock pedal. If buying now, probably would get Velox's spacer kit. It relocates pedal by similar amount as PST's, but it's cheaper & has extra adjustability. |
Drives: 2014 Ultramarine FR-S
I had the same problem and think pedal spacers are ridiculously priced for what they are. Decided to try the SRP pedal first and it works beautifully. Well priced and looks OEM:
http://www.srpracing.com/pd-brz-fr-s...pedal-only.cfm |
Drives: 2014 GT86
Spacers also look OEM. As in - you don't see them, just pedal is where it should be if not all those sudden acceleration lawsuits
#8 | |
not playing cards
Yes. Before committing, though, I recommend practicing threshold braking. You may find that the brake pedal is actually pretty well matched to the gas when you're properly laying into it.
#10 | |
The Dictater
If you don't want to spend money on it, I used to press my toe on the brake lever above the pedal in my SAAB which actually lined up pretty good. Not sure how that would work in a brz though. |
#11 | |
not playing cards
Today, after the conversation steered towards spacers, I thought about how it would affect my technique. I realized I wouldn't like it. ...for the same reason you stated yesterday.
#12 | |
The Dictater
#13 |
not playing cards
I totally agree with you, though. The heights of both seem just about perfect for the late braking downshift.
| FS: OEM Pedal Box | MicheleAbbate | Interior Parts (Incl. Lighting) | 14 | 02-26-2020 02:02 PM |
| Gas Pedal Adjustment | ML | Cosmetic Modification (Interior/Exterior/Lighting) | 32 | 05-01-2017 09:26 PM |
| Pedal dance | Simqc | Issues | Warranty | Recalls / TSB | 6 | 05-22-2016 09:56 PM |
| DIY SRP pedal install | Doborder | Northern California | 2 | 05-11-2013 06:05 PM |
| Gas pedal | tintumz22 | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 08-22-2012 09:42 AM |
