Old 07-20-2017, 10:26 PM   #1
Fainten
Fainten's Avatar
Drives: white brz
Help, I need assistant
So today I go on my daily drive, my clutch is working fine. 10 minutes later I get a code for PO351 i check and clear it.Now getting my car to move in 1st gear is hard. Its like the clutch was not grabbing or its loosing power. I have to increase gas for it to start which i don't like. I keeped driving and no code. But still hard to start moving in first gear.can any one help me with this. (I've done all the maintenance, i don't track at all only do driving in nice curves and push it hard only at those times. The rest of the time i drive as a normal civilize too school.)
Any one had this?
Fainten is offline   Reply With Quote
Old 07-20-2017, 10:55 PM   #2
humfrz
Well, no ...... but your code indicates this:
https://repairpal.com/obd-ii-code-p0351
Have you messed with the clutch lately ...??
humfrz
Old 07-21-2017, 12:06 AM   #3
Silver Supra
Hombre
Silver Supra's Avatar
Drives: 1994 Supra Turbo
So......clearing a code does not fix the problem, right?
Right.
I think the code was trying to tell you something.
A Toyota Racecar A Toyota......................Because.
Anyway, should not palindrome be spelled palinilap?
Silver Supra is offline   Reply With Quote
Old 07-21-2017, 12:56 AM   #4
steve99
As above P0351 is cylinder 1 coil pack usually but can be spark plugs or connection to coil.
You going to need to do some diagnostics or take it to a shop to sort the problem. It probably hard to get off the line as it probably not firing properly on cylinder 1 pack
Old 07-21-2017, 12:59 AM   #5
Turdinator
Señor Member
Turdinator's Avatar
When you clear the a code the ECU resets and has to re-learn trims and throttle positions etc. Drive it for a bit and it will improve.
I am fairly sure that code is for a misfire which is fairly common for these cars. If you ignore it, it will disappear after a few start ups. Eventually you will get a noticeable misfire at which point you can replace the coil for cylinder 1 and it will be fixed.
1974 TA22 Celica
2013 86 GT
Assistant needed, blacking out headlights ducky369 Northern California 27 01-25-2015 02:50 AM
Extreme Dimensions is hiring for customer service rep & sales assistant Extreme Dimensions Southern California 2 01-13-2015 06:38 PM
Automatic — Your Smart Driving Assistant DBacon1052 Electronics | Audio | NAV | Infotainment 3 03-12-2013 07:56 PM
