Northern California NorCal
Old 01-24-2015, 01:23 AM   #1
ducky369
Drives: 2014 Frs
Assistant needed, blacking out headlights
hey guys, I want to blackout my headlight, I have the base FR-S. Got the car wrapped and should be coming back in a few days. However, I don't have the oven or experience in blacking out my headlights. In this case, i should be called the assistant and you're the main surgeon. Is it a one day job? This is the only car i have and i don't have spare headlights to use.
If someone don't mind lending me a oven to use and helping me out, i'll buy some KFC and beer(or rootbeer for the under 21s)!
thanks!
ducky369 is offline   Reply With Quote
Old 01-24-2015, 01:39 AM   #2
Kaotic Lazagna
Drives: GR Corolla
Heat gun works great as well. I actually prefer the heat gun over the oven.
The Following User Says Thank You to Kaotic Lazagna For This Useful Post:
ducky369 (01-24-2015)
Old 01-24-2015, 01:45 AM   #3
killboy
killboy's Avatar
Drives: 1FRS, 1 BRZ, 2S2000s, Evo8, Dak.R/T
Same here. You can get a heat gun new for about $20, just be careful if you've never used one...they're like an amped up hairdryer, but they will seriously burn you or anything the nozzle/tip touches. Keep some distance and don't let the tip touch anything when you're setting it down between sessions of heating and prying.
Works great though, just take your time, and understand that the first bit of separation is the most time-consuming...it will seem like it's never going to come apart, but just keep heating and slowly prying, and then suddenly it will start to spread and it's all butter from there.
killboy is offline   Reply With Quote
Old 01-24-2015, 01:47 AM   #4
ducky369
Drives: 2014 Frs
Would you like to help? I have no experience with painting and using a heat gun.
I'm scared I'll melt my housing
Old 01-24-2015, 01:53 AM   #5
ducky369
Drives: 2014 Frs
I have a heat gun at home, but I never used one. I am scared to melt the housing, that's why I want someone with experience to help :/ and I'm probably going to do a very bad painting job.
Old 01-24-2015, 01:53 AM   #6
Kaotic Lazagna
Drives: GR Corolla
I would help, but I have no clue where my heat gun went (they have cheap ones at Harbor Freights). Also, I'm always at work -_-
imho, you should have a second pair of headlights. If you do use a heat gun, do not stay stationary at an area for too long. Sweep back and forth a few inches and carefully pry the lens from the housing.
Also, I used bbq grill paint on my Yaris headlights. Lol. Figured they would work well with the headlight heat.
Old 01-24-2015, 01:55 AM   #7
Kaotic Lazagna
Drives: GR Corolla
Gotta take apart the parts you want to paint. Also prep them. Washing with dish wash soap at the very least. Some high grit sanding would be best cuz you'd want a surface where the paint will adhere to. Otherwise, over time, the paint will start peeling off showing the chrome again.
Old 01-24-2015, 01:56 AM   #8
ducky369
Drives: 2014 Frs
I have a heat gun! Dad bought it from home depo, he's has most hardware tools. Just need someone with experience. It's not in a rush, can be accomplish when you have free time.
Old 01-24-2015, 01:58 AM   #9
Kaotic Lazagna
Drives: GR Corolla
What I'd be more concerned is taking off the front bumper as I've read that it never stays on the same.
My days off are Tuesdays and Wednesdays, even then I usually end up having to go into work. Where are you located, btw.
Old 01-24-2015, 02:00 AM   #10
ducky369
Drives: 2014 Frs
I'm located in alameda people say the hardest part is the side markers.
I would get a second pair if I had the money but hey poor college kid here :/
Old 01-24-2015, 02:02 AM   #11
Kaotic Lazagna
Drives: GR Corolla
Ah, if I still lived in Union City, it would be much easier. Haha. I'm across the way in Vallejo. Hopefully someone closer to you would be able to lend a hand.
Old 01-24-2015, 02:03 AM   #12
Kaotic Lazagna
Drives: GR Corolla
I'm a poor college grad. Haha
Old 01-24-2015, 02:06 AM   #13
ducky369
Drives: 2014 Frs
Ah, it's about 40 mins away? My gf lives in Richmond it's not that far from Richmond right?
Old 01-24-2015, 02:11 AM   #14
Kaotic Lazagna
Drives: GR Corolla
It's a little longer than 40 minutes. I work near Richmond at Toyota Marin, and even then that's 40 minutes away from where I live (parking lot to parking lot).
Extreme Dimensions is hiring for customer service rep & sales assistant Extreme Dimensions Southern California 2 01-13-2015 05:38 PM
Blacking out headlights anyone? bhbnuckle CANADA 10 03-24-2014 05:41 PM
Anyone thought about blacking out the stitching? tracerit Cosmetic Modification (Interior/Exterior/Lighting) 12 04-12-2013 09:31 PM
Automatic — Your Smart Driving Assistant DBacon1052 Electronics | Audio | NAV | Infotainment 3 03-12-2013 06:56 PM
