Old 07-17-2017, 12:56 PM   #1
brillo
Drives: 2013 Firestorm FR-S
Crank Pully Install Tool?
So I've watched several DIY videos and searched the forum, I'm a bit concerned about the techniques I'm seeing to remove the stock crank pully given the potential for issues.
Are are of the generic tools to hold the cranky pull stable compatible with our car? Has anyone found a good tool that makes the process easier? Is there a shop tool that helps?
2013 Firestorm FR-S, MTX, build date 1/13.
brillo is offline   Reply With Quote
Old 07-17-2017, 01:11 PM   #2
byun
byun's Avatar
Drives: 2015 BRZ CWP
When I swapped the ATI Damper pulley on mine I just put it in 6th gear and had the GF step on the brakes and then used a long breaker bar. It was tough, but made it pretty easy.
byun is offline   Reply With Quote
Old 07-17-2017, 01:21 PM   #3
humfrz
I suggest you just close up your tool box, shut the hood and slowly back away from the car ....... there ain't nutten wrong with the crank pulley that came with the car ......
humfrz
Old 07-17-2017, 04:31 PM   #4
MurderousPandas
MurderousPandas's Avatar
Drives: 2013 Scion FRS
6th gear helps as it has most resistance. And a long breaker bar is needed. As for removing it, once the bolt is loose, just shake the pulley so it's not "glued" to the crank, then unbolt entirely, remove, and install the new one. Took me 30 minutes using a shovel as a breaker bar.
Sent from my HTC6535LVW using Tapatalk
MurderousPandas is offline   Reply With Quote
Old 07-17-2017, 04:42 PM   #5
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Do you have A/T?
Old 07-17-2017, 05:11 PM   #6
brillo
No I have the manual transmission, I'm just concerned about damaging a bearing or other internals given the crank can still move in most of the DIY installs I've seen.
I have seen one tool that looks like a giant wrench which appears to allow you to hold the crank pully with another individual while you crack the bolt.
Old 07-17-2017, 07:05 PM   #7
norcalpb
norcalpb's Avatar
Just be man and apply 120lbs and the nut will come off. The hard part is if the stock pulley is fused to the front of the engine, then you might pull off something you didn't intent to.
Old 07-18-2017, 05:40 AM   #8
Trueweltall
Trueweltall's Avatar
Drives: 2016 Subaru BRZ
I bought the tool instead of doing the 6th gear "trick", I tried this but the car would move even when it was in gear and with the parking brake on. (Company23
Subaru Crank Pulley Tool 1 v2)
Trueweltall is offline   Reply With Quote
Old 07-18-2017, 10:10 AM   #9
Somerandom18
Drives: 2017 manual BRZ
That's crazy. I had to use a 4 ft breaker bar and all of my strength to get the pulley off and the car never moved in 6th.
Sent from my Pixel XL using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 07-18-2017, 10:53 AM   #10
humfrz
Which way did it move ....... sideways ......??
humfrz
Old 07-18-2017, 11:36 AM   #11
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
There is a GrimmSpeed removal tool, but doesn't fit directly in our pulley. I had the same concerns as you and I ordered this tool. It doesn't work. As others mentioned, try the trick with the 6th gear and handbrake. You'll need also a long breaker bar. It should work. I haven't heard of any issues using this procedure.
Old 07-18-2017, 05:06 PM   #12
MurderousPandas
humfrz
I don't think the car would've moved much, but mine had a lot of give before breaking
Old 07-18-2017, 06:20 PM   #13
Trueweltall
humfrz
It would move forward.
Old 07-18-2017, 07:27 PM   #14
humfrz
Oh.....if the parking brake had the rear wheels locked up ....... if the car moved forward, I reckon the clutch was slipping .....
humfrz
Crank Pully Wobble... With video Norcalmav23 Engine, Exhaust, Transmission 33 09-25-2019 07:26 PM
Stock Crank Pully brenesk91 Engine, Exhaust, Bolt-Ons 0 12-02-2015 08:29 PM
FS: Raceseng Revo Crank Pully stueck9356 Engine, Exhaust, Bolt-Ons 13 02-01-2015 10:44 AM
Perrin Crank Pully firl21 Engine, Exhaust, Transmission 27 09-15-2014 07:50 PM
CEL After PERRIN Crank Pully Install milko002 Engine, Exhaust, Transmission 9 02-05-2013 02:11 PM
