Old 07-15-2017, 06:53 AM   #1
snk828
snk828's Avatar
Drives: raven FRS
Unhappy After market Header problem!!Everyone should check for your car!!!
[url=https://flic.kr/p/VtdTBS]
Who is running after market header with OEM intake tube should check for the melting on the bottom of the intake tube. I have been running after market header for little over a year, I realize my oem intake tube has a hole on the very bottom.
snk828 is offline   Reply With Quote
Old 07-15-2017, 08:41 AM   #2
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
What kind of header are you running? Is it a long tube that routes up and then back down like on the left or a regular header like on the right?
Old 07-15-2017, 08:47 AM   #3
murdoc
Sometimes I'm wrong.
murdoc's Avatar
Drives: '13 FR-S/'96 240SX
If you're running a nameless or similar header you're supposed to remove that resonator and plug it.
murdoc is offline   Reply With Quote
Old 07-15-2017, 04:38 PM   #4
snk828
snk828's Avatar
Drives: raven FRS
This is what I have , JDL EL with coating.
Old 07-15-2017, 04:43 PM   #5
snk828
snk828's Avatar
Drives: raven FRS
I'm running the JDL header with costing.The header comes with no instructions, and the resonator doesn't contact the header at all.
Old 07-15-2017, 06:08 PM   #6
Teseo
Drives: frs
Replace with inlet hose?
Old 07-16-2017, 06:18 AM   #7
snk828
snk828's Avatar
Drives: raven FRS
I replaced with cusco intake tube.
Old 07-16-2017, 08:10 PM   #8
CTB727
Drives: 2013 Subaru BRZ
Yep, had that happen to me when I had a JDL EL header.
CTB727 is offline   Reply With Quote
after market header / stock exhaust FR-Sky Software Tuning 1 08-02-2016 07:20 PM
EJ25 market check Salemate Canada Classifieds 2 01-01-2016 10:23 AM
Check engine light after Header Install g0odspeed Scion FR-S / Toyota 86 GT86 General Forum 8 05-27-2015 02:39 PM
New Header on the market!! wbradley Off-Topic Lounge [WARNING: NO POLITICS] 4 04-01-2014 09:14 PM
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
