Old 07-15-2017, 04:35 AM   #1
Adam_L
Adam_L's Avatar
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
catted header options?
Hello all,
Just doing some preliminary research. It seems like a header + tune is the way to go, for that torque dip between 3500-5k rpm. Fairly inexpensive effective route.
I'm in CA, so I'd need a catted header. What brands offer catted ? It seems like most headers I see are catless. Im open to UEL or EL.
Thanks in advance.
Math is like Love, simple idea at first that quickly gets complicated
Adam_L is offline   Reply With Quote
Old 07-15-2017, 06:39 AM   #2
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
The FT86 Speedfactory catted header is a good low-cost option:
http://www.ft86speedfactory.com/ft86...el-header.html
If you want to go on the premium side there is also the Fujitsubo catted header:
http://www.ft86speedfactory.com/fuji...2013-ft86.html
Old 07-15-2017, 06:58 AM   #3
Yoniyama
Drives: BRZ 2018
In California, annual smog inspection is required after 6 years. Replacement of OEM header with an after-market unit, with or without CAT, will likely flunk the visual inspection part of the smog check, unless:
(1) you are very friendly with the smog check people; or
(2) the after-market unit has a California smog approval (which is highly unlikely).
If you don't want to swap headers for the smog check, I know of one equal-length, CAT attached, and with CA smog approval: the 2017 OEM unit for manual transmission.
Yoniyama is offline   Reply With Quote
Old 07-15-2017, 07:23 AM   #4
steve99
Isn,t it illegal to chamge anything emmissions related in CA
So if your getting a tune you might as well jist get catless header ?
Ft86 speedfactory do a catted header if your after one though
Other option might be jist to tune your car to e85 with stock header, then nothing looks different and you get a nice power boost with just e85 and tune
Old 07-15-2017, 06:24 PM   #5
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
JDL and P&L also offer catted headers for our cars.
Pointmutation is offline   Reply With Quote
Old 07-16-2017, 01:32 AM   #6
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
There is no CARB approved aftermarket catted header for our cars so all will still be illegal. Swap at your own risk
Old 07-16-2017, 08:33 AM   #7
bfrank1972
Drives: 2013 FR-S Argento
Yup I have a P&L catted header, it's awesome. Here's a nice used one in the classifieds:
http://www.ft86club.com/forums/showt...ghlight=header
bfrank1972 is offline   Reply With Quote
Old 07-17-2017, 01:21 AM   #8
Adam_L
Adam_L's Avatar
Lightbulb
Correct, so the '17+ manual OEM header is really the only one to go with.
So I have to find someone, most likely in another state to sell me theirs , or find a totaled FRS / BRZ '17 manual, and get the header out of that one.
Thanks to all that chimed in.
Old 07-17-2017, 07:03 AM   #9
LancePower
Drives: 2020 BRZ tS
How much power is the 2017 OEM Header going to net you?
One or two ponies?
LancePower is offline   Reply With Quote
Old 07-17-2017, 09:44 AM   #10
churchx
churchx's Avatar
Drives: 2014 GT86
With same tune - probably about that. Also it's not 100% fool-proof warranty for CELs to not appear if you retrofit it to older cars, as you run it with older ecu tune, that expects different header. And imho it technically also is not legal replacement .. just that harder to notice. So imho that small gain is not worth the hassle of getting it & retroffitting. If one decides on spending on improving car, then better at least for substantial/noticeable gains that actually can be felt by 'butt-dyno'. In our case - catless aftermarket header.
churchx is online now   Reply With Quote
Old 07-17-2017, 11:45 AM   #11
driggity
Drives: Silver Coupe with a Boxer
A tune is easier to swap back to stock when it comes to emissions time so for us lazy people or those who don't want to pay for swapping headers twice each time emissions comes up just there is something to be said for just a tune even though it is technically just as illegal. Or you can just go all the way to an emissions legal forced induction solution.
driggity is offline   Reply With Quote
Old 07-17-2017, 12:06 PM   #12
mrspindlelegs
Drives: 2014 Scion FR-S Monogram Series
Don't forget to check the sticky near the top of this forum subsection:
http://www.ft86club.com/forums/showthread.php?t=81491
2014 FR-S Monogram Series, Raven Black, MT
Mods -ARP wheel studs, Bilstein B6, Michelin Pilot Sport 4S, Diode Dynamics "Tail-as-Turn" kit.
Fuel Economy - Best was 37.2 mpg, Worst was 28.2 mpg
Semi-truck crushed it on 1-1-2023.
mrspindlelegs is offline   Reply With Quote
Old 07-17-2017, 04:10 PM   #13
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by Adam_L View Post
Hello all,
Thanks in advance.
Others have already mentioned it but it depends on if you want it for street legal purposes, or just to get rid of the smell.
For first 6 years of ownership no one will care what you do, after that you may or may not need biannual smog checks, it really depends on what county you live in.
Aftermarket catted header is not legal in CA in a strict sense. In practice, you can do whatever you want until you need a smog check, or whenever you get pulled over for a smelly exhaust, whichever one is first.
It's illegal to knowingly increase emissions of a car in virtually ANY state in the US beyond the established state or federal minimum. It is a federal crime to remove a functioning catalytic converter without replacing it.
Whether you want to enforce the laws or not depends on local priorities. Some states don't care because they don't have an air pollution problem (or pretend there's no air pollution problem).
-alex
Old 07-17-2017, 10:23 PM   #14
Adam_L
Adam_L's Avatar
Thanks for the responses. Yes, I'd like it for street legal reasons, and not have to remove every 2 years for a smog check (post the initial 5-6 year of when a car is new).
I was thinking header and tune ( to remove as much of that torque lag as possible 3500-5k rpm). I'm not in any rush to do anything this minute, but was thinking 1-2 years out. I'll do more research and come back to this. I'm also unsure on EL or UEL header. I know UEL gives more of a boxer rumble , but not sure if there is any real performance difference (more hp/torque) by going with one over the other.
catted header or catted front pipe? gabeg86 Engine, Exhaust, Transmission 28 10-13-2015 12:32 PM
JDL Catted UEL header VS ft86speedfactory catted UEL Teclis Engine, Exhaust, Transmission 4 05-28-2015 02:19 PM
Catted header or catted front pipe? wilfredwong Engine, Exhaust, Transmission 5 02-09-2015 06:11 PM
what options do I have for a catted UEL header? giorgi0424 Engine, Exhaust, Transmission 33 06-05-2014 10:06 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
