Old 07-14-2017, 01:28 PM   #1
C3
C3's Avatar
Drives: Scion FR-S
Do I need toe arms?
I am currently looking to move to coilovers and lower my FRS. On my last FRS I went with B16's and the whiteline F&R camber kits. If I am going to go with LCAs on the rear this time instead of a camber kit, do I need adjustable toe arms as well? thanks
18x9.5 squared setup
255/35/18
C3 is offline   Reply With Quote
Old 07-14-2017, 02:04 PM   #2
cjd
cjd's Avatar
Drives: 2017 BRZ
I have had no problems getting toe to zero (or a touch of toe-in) with rear camber between -2 and -2.7 degrees. Depending on your target camber, you could be fine.
The Following User Says Thank You to cjd For This Useful Post:
C3 (07-14-2017)
Old 07-14-2017, 02:50 PM   #3
C3
C3's Avatar
Drives: Scion FR-S
Im looking to have 1.5 degrees in the rear so I may need toe arms
Old 07-14-2017, 04:42 PM   #4
strat61caster
strat61caster's Avatar
Unlikely, I've never come close to using the full adjustment on the factory toe arms, they've got plenty of adjustment range.
I think they're only necessary if you're chasing stance or if you want something easier to adjust.
ineedyourdiddly
C3 (07-14-2017)
Old 07-14-2017, 07:21 PM   #5
wparsons
wparsons's Avatar
You typically only run into issues with the stock toe arms if you're adding, or removing, a lot of camber. If the car is slammed and you want -1.5, you might need toe arms. If it's not dropped that much you're probably fine.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
C3 (07-14-2017)
Old 07-14-2017, 11:18 PM   #6
twag4
Drives: frs
I can get -2 no problem. I tried to get -1.25 and there was not enough adjustment in stock toe. I was changing back and fourth for auto x and daily driving. I have since just settled on -2 and deal with tire wear.
twag4 is offline   Reply With Quote
Old 07-14-2017, 11:38 PM   #7
C3
C3's Avatar
Drives: Scion FR-S
I'm not looking to lower the car that much... I think I will see how the LCA install goes and get toe arms later if needed. There are a lot of mixed opinions when it comes to these squared set ups. I just don't want to get into the install and wish I had the parts, but also don't want to waste the money of it's not necessary.
The Following User Says Thank You to C3 For This Useful Post:
strat61caster (07-15-2017)
Old 07-16-2017, 08:52 PM   #8
wparsons
wparsons's Avatar
How low is the car?
flickr
Old 07-16-2017, 10:43 PM   #9
twag4
Drives: frs
Originally Posted by wparsons View Post
How low is the car?
1 1/4" roughly, all around
Adjustable control arms and Toe arms zumin Brakes, Suspension, Chassis 12 07-08-2015 06:54 AM
DME Lower Control Arms and DME Toe Arms - Review FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 02-24-2015 11:53 AM
GTSPEC rear control arms & toe arms review Jesse Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 08-23-2013 03:20 PM
