Drives: 2017 Toyota 86
Best 2017 MT Drop-In Filter?
I'm gonna be in the market for a drop-in filter for my 17 Toyota in a bit, I was wondering if others with MY17's have picked up any of the available drop-ins for them yet and have any opinions on them?
I believe the only available ones are the Works for $65 and the Blitz for $46. |
Drives: 2014 GT86
I guess, that it will be similar to drop in filters for older cars, most of them performed somewhat similar so one can go whichever vendor one prefers.
.. or stock. From what i've seen, one of MY2017 changes were less pressure drop air filter too. Hence probably less to gain replacing with aftermarket one. |
Drives: 2014 Scion FR-S Firestorm
I personally went with the K&N Drop in Filter. But honestly even with the airfilter, didn't really make a noticeable different on the butt dyno.
RYO - 2014 Firestorm FR-S - Canada
Recommended Blog on Aftermarket Parts for the 86/FRS/BRZ |
Drives: '14 981CS, '99 NB1
Stock.
Don't waste your money. |
Drives: 2017 manual BRZ
I have a 2017 mt and didn't notice a difference switching to an aftermarket filter.
Sent from my Pixel XL using Tapatalk |
Drives: C5, GT-86, '24 Colorado TrailBoss
Used the Blitz filter in the stock box with perrin '17 specific tube
Drives: 2022 GR86
I did the Blitz with a Perrin inlet tube as well. You won't notice any difference, but it is a cheap and easy mod.
[ame]http://www.youtube.com/watch?v=X-Nuf1rHYgQ[/ame]
Yeah your not gonna feel much on its own but its a good first mod. If you do exhaust and tune later on they will all work together to get air in/out faster
Drives: 2014 GT86
It helps on pre-MY2017, doesn't on newer. 50$ better spent elsewhere. Even if it doesn't hurt anything, even if it's simple to do, it's less money/budget for something that actually DOES something. Other mods that don't do anything at least are usually visual ones that one can see. One doesn't split open regularly airfilter box to admire new blingy airfilter
#10 |
Drives: car
I love my Perrin drop-in filter in my '13. Tone from the sound tube is a bit darker, bassier, gives a good thrum. Also I noticed easier starts in 1st, better low rpm response from 600-1000 rpm.
#11 | |
#12 |
Drives: 2017 CWP BRZ w/ PP
#13 |
#14 |
Drives: 2019 WRX
I like my Cosworth
| Tags |
| 2017, air, filter |
| 2017 BRZ MT Drop-In Filter | Drambeenie | Engine, Exhaust, Transmission | 23 | 03-03-2017 12:17 AM |
| Need Help With Drop-In Filter | Ammunition | Engine, Exhaust, Transmission | 5 | 01-01-2014 03:29 PM |
| Which dry drop in air filter? | DarkestBuddha | Engine, Exhaust, Transmission | 17 | 09-10-2013 12:41 PM |
| DIY drop-in filter? | aceangel | Engine, Exhaust, Transmission | 18 | 04-25-2013 10:42 AM |
| Drop In filter test! Stock, Apexi, No filter | RallySport Direct | Engine, Exhaust, Transmission | 14 | 06-25-2012 02:40 PM |
