Old 07-09-2017, 03:46 PM   #1
Ninjadanny
Drives: Scion FR-S
Tow Strap Takata Installation ???
Hi,
I just get this Takata tow strap that i wanna install in front of the FR-S as one the picture below. I want to let some part of the tissu go out by the fence.
But the original hook does not fit and is too long to do such things and the steel section of the takata tow strap is too big to enter in, i guess i need to cut somewhere etc..
Is there anyone who already intall this and who knows how to install it ?
Is there some tool i can use ?
How to do the fence cut in the plastic without domaging it, is there a guide to help you cut in the right place, and wich tool do you use ?
Thanks
Ninjadanny is offline   Reply With Quote
Old 07-19-2017, 01:47 AM   #2
Ninjadanny
Drives: Scion FR-S
Nobody know ?
Old 07-19-2017, 10:09 AM   #3
JazzleSAURUS
Drives: 15 BRZ LTD, 05 FXT
I'm not 100% sure what you're getting at here, but I imagine you're looking for some tips on installing this properly.
I would tackle this project by first removing the bumper.
From there, you've got to find a point to anchor it.
You could start by either finding a bolt that threads into the stock tow hook point, bolting it in, and threading it through the bumper hole. Then, I'd put painters tape on your tow hook cover cap thing, and dremel a slot in it.
If this sounds confusing or difficult, I wouldn't attempt this project.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
JazzleSAURUS is offline   Reply With Quote
Old 07-19-2017, 11:22 AM   #4
ikuGANO
ikuGANO's Avatar
Drives: 2016
Couldn't have said it anymore. Just be careful using with the dremel...
ikuGANO is offline   Reply With Quote
Old 07-19-2017, 03:19 PM   #5
G-Man
G-Man's Avatar
Drives: 1980 corvette, 2014 Subaru BRZ
[ame="https://www.youtube.com/watch?v=HQXsxJOXOSY"]Tow Strap Install | 2013+ BRZ/FRS/GT86 - YouTube[/ame]
do this on the opposite side, and be careful with the dremel when you make a hole in the cover
G-Man is offline   Reply With Quote
Old 07-19-2017, 08:56 PM   #6
Ninjadanny
Drives: Scion FR-S
I see, actually its more for the look then for the use of it.
Alternatively i saw some guy said they cut the metal part to weld it to the stock tow hook that they cut also to the specific lenght.... ouf
I guess my ideal goal is to find a pieces that can be thread into the stock tow hook point and that is smaller in lenght so i could close the cap after. Also easy to remove if i want to switch for a license plate tow hook relocation kit per exemple
Thanks for the info
Old 07-19-2017, 10:41 PM   #7
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
https://www.ebay.com/i/222369861884?...D1262090756379
Old 07-19-2017, 11:51 PM   #8
Ultramaroon
not playing cards
Ultramaroon's Avatar
Isn't that usually the case?
Old 07-20-2017, 12:27 PM   #9
JazzleSAURUS
Ugh I hate that. We have one at each end on our LeMons car. Very functional, I've proved that point more times than I care to admit.
Old 07-20-2017, 12:33 PM   #10
Ultramaroon
not playing cards
I would prefer a strap over the stock insert. Those things are known to snap under the slightest side load. I watched the angle like a nervous parent the one time we used it to winch the car onto a flatbed.
Old 07-20-2017, 12:33 PM   #11
Pat
Pat's Avatar
Drives: 2023 BRZ
Originally Posted by Summerwolf View Post
Thanks. I ordered one of these.
Old 07-20-2017, 12:43 PM   #12
JazzleSAURUS
That's why we like the straps! Right to the bumper beam, hole through the bumper cover, or expose the beam, bolt right through the whole shebang.
Because, RACECAR!
Old 07-20-2017, 12:46 PM   #13
Pat
Pat's Avatar
Drives: 2023 BRZ
Another (admittedly theoretical) benefit is if you tag the wall with a toe strap instead of OEM tow hook, there is less chance of bending the frame the toe hook is screwed into. Does anyone have any thoughts on how likely this theory is to be true?
Old 07-20-2017, 01:11 PM   #14
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
Probably as likely as it is to hit that exact spot in the first place?
venturaII is offline   Reply With Quote
intallation, tow strap takata
Tamara tow strap Dreyup Cosmetic Modification (Interior/Exterior/Lighting) 13 07-09-2017 04:03 PM
Tow strap for bars FutureFT86 Cosmetic Modification (Interior/Exterior/Lighting) 3 01-17-2017 07:01 PM
Fs: TRS tow strap $30 Sold. Jcl Exterior Parts (Aero, Lighting, Etc.) 3 06-04-2015 03:26 PM
Takata tow strap Thatguyjeremy Cosmetic Modification (Interior/Exterior/Lighting) 13 05-20-2015 09:25 AM
FS: Takata Tow strap Tengu Exterior Parts (Aero, Lighting, Etc.) 1 02-26-2014 08:36 AM
