UCanThrottleMyBody
Drives: 2015 GM 370z Sport
Maintaining DI
Was reading a sign in my local wal-mart and read that over time the hoses that spray the the engine can get clogged and dirty causing less than perfect spraying.
How does one go about servicing a DI system? Also, how often must a DI system be serviced? |
Kouki-Monster
Run quality fuel. Run fuel with little or no ethanol content.
Every 20k miles or so perhaps run a bottle of Redline injector cleaner through the system. I've heard a decent amount of positive review about this and never anything bad so it's a small investment.
Rich Anderson
EMPOWER AUTO |
Drives: 2013 Scion FR-S Firestorm Red MT
I'm a fan of the Lucas cleaners as well, I usually run them after every oil change.
Drives: honda accord 08 EX-L V6
by knowing how fuel injectors work and how it should be cleaned, the idles of your car will be so smooth. Im also using lucas cleaners when I filled the tank with gas, it really worked and provided boost in power
First 86
Drives: Scion FRS Argento Automatic
What about Techron? Anyone use it? I was using it in my Mini Cooper, seemed run more smoothly.
Life is short...NO BORING CARS |
